Go to Post It's not about the robot. It's about science, technology, engineering, and mathematics. - Ether [more]
Unread 08-02-2003, 01:20
Carl Owenby Carl Owenby is offline
#0654 (Maclay Robotics)
Carl Owenby is an unknown quantity at this point
Air compressor never shuts off
Our air compressor never shuts off. The control circuit works because the compressor will turn off when we unplug the pressure switch from the RC, but the air pressure never gets high enough to operate the pressure switch. We can maintain a top pressure out of the compressor of only 65-70 psi.
Any suggestions as to what might be wrong?
There are 10 kinds of people in this world; those who understand binary and those who don't.
Unread 08-02-2003, 01:44
REVving up for a new season
FRC #2848 (All-sparks)
how is your system setup because the pump should put out about 120psi and if it is only putting out 65-70 then that explains why the pressure switch isn;t working because it only activates when pressure is above 110 psi and re activates when pressure is less then 90psi My sugestion is to check the following:
the gauge should be off of one of the storage tanks not off the pump directly
check for leaks
check the location of the regulator and make sure it isn't restricting the flow before the tanks because you are alowed to store up to 120 psi in the tanks but only have 60 in the system
I guess my major recomendation is to just check your setup vs the one in the pneumatics guide and see if something is set up wrong
Unread 08-02-2003, 01:49
Patrick Wang Patrick Wang is offline
#0115 (MVRT Alumni)
Patrick Wang has a spectacular aura aboutPatrick Wang has a spectacular aura about
Send a message via AIM to Patrick Wang
Make sure your regulator is plugged in right.
The Air flows only one way correctly.
There should be some indication on the regulator as to the way the air flows
Patrick Wang
WRRF
Unread 08-02-2003, 10:01
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
check for leaks. If you didn't put teflon tape on all of the brass fittings, that could be part of the problem. The tape acts as a bit of a lubricant to make the fittings tighter without damage to the threads thus making a tighter seal.
If you aren't sure if your system is leaking, crank up the pressure to 60-70psi (which you say is your current max) and, with wet fingers, hover your fingers over each fitting closely. (Wet fingers make it easier to feel the air when it's a light leak).
A better way to do this is to take soapy water, stir it with your finger and wipe it around all the connections. If a connection starts to bubble, then there is a leak.
Unread 08-02-2003, 23:34
Regulator improperly connected
Thanks for the help. We found the primary regulator was improperly connected. We also found some minor leaks when we soap tested.
Where to get air muslce pneumatics? Adam Y. Pneumatics 5 27-12-2003 23:17
Air ship edomus General Forum 5 19-11-2003 18:17
What are pneumatics? Aignam Pneumatics 23 16-10-2002 21:17
Air Force Academy archiver 2001 2 24-06-2002 03:41
Air Fare to Florida archiver 2000 0 23-06-2002 22:16
