Go to Post "Scientists investigate that which already is; Engineers create that which has never been." - Albert Einstein - JamesCH95 [more]
Unread 04-12-2013, 00:13
yash101 yash101 is offline
AKA: null
Propeller controlling Victors
I was wondering if it were possible to wire up a Victor PWM to a propeller chip. Would the Victor send any 12V feedback that could damage the chips?
Unread 04-12-2013, 00:29
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Re: Propeller controlling Victors
On the product page here. Under 'Inputs' it talks about the PWM connection.
Edit: The user manual has more detailed information too.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 04-12-2013, 02:50
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
The FRC legal speed controllers use an optoisolator on the PWM input. That means the only thing connected to the PWM circuit is an LED so it can't back feed any voltage.
Unread 04-12-2013, 07:57
AKA: null
Thanks, everyone. That's all I need!
Unread 04-12-2013, 09:14
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Works fine, but when I did it I used a level shifter to get the output of the Propeller board to 5V (I never tried it with the outputs themselves I had no reason to do that but it should work). Talons also work. Jaguars on PWM and with the Microchip CAN transceivers also work. Just get the signal correct or you'll get strange behavior.
I used the level shifters for several reasons not the least of which was to prevent a user wiring error from impacting the Propeller itself. An error like connecting the 6VDC power supply for a hobby servo to the PWM output for example is easy to make with loose wires. The worst case someone fries the level shifter.
If in doubt a simple 2N7000 MOSFET is fine level shifter and quite cheap:
https://www.sparkfun.com/products/8745
How it works:
http://husstechlabs.com/support/tuto...level-shifter/
Unread 30-12-2013, 22:46
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
reported
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 01-01-2014, 23:55
AKA: null
??That isn't spam??
