Originally Posted by ehfeinberg
[*]Red alliance has a major advantage (for experienced teams) over blue alliance because of where the loading stations are. It is much easier to pick up a crate from the loading station then one scattered around the field, so this will be the main supply of crates for each alliance. Because of this, the distance from the red alliance loading station around the tank to the 2pt goal is much shorter than the distance from the blue alliance loading station to the blue 2pt goal. Also, the distance from the red alliance loading station under the overpass to the 1pt goal is much closer than the same trip by the blue alliance. This could allow red to score a few more crates a match just because of shorter driving times. However, if you are a low skilled team who is taller than 30" but can only score in the 1pt goal, you would much rather prefer the blue alliance.
The distances to any particular object is the same for both alliances. I'm unsure of what you're referring to.
