Go to Post Improve yourself. Try not to tear others down. - Tom Line [more]
Go Back   Chief Delphi > Technical > CAD
Unread 05-12-2013, 10:54
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Re: Our prototype drive chasis(only weighs 27lbs!)
Originally Posted by Akash Rastogi View Post
What led you to choose this over something like a mecanum setup?
Agility
Is it more agile than a mecanum drive? I can definitely see the weight advantages of omni and the corner setup, but I'm just wondering if and how it's more maneuverable than a mecanum drive. Can you prove some numbers? Like traverse speed in degrees per second or seconds per 360 degrees, straight (meaning moving parallel to one of the frame pieces) speed, and diagonal (moving at 45 degrees to the frame pieces) speed?
I've always thought that:
Mec Straight Speed > Omni Straight speed
Mec Diagonal speed < Omni Diagonal Speed
Mec Strafe Speed = Omni Straight Speed
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
