Go to Post Don't over analyze every possibility. Studying a problem too much doesn't help any more than not studying it enough. - dlavery [more]
Unread 08-02-2003, 22:07
Tonay K Tonay K is offline
Tonay K is an unknown quantity at this point
Send a message via AIM to Tonay K
Plastic Motor Mounts?
Most of the teams I've talked to are making their drive motor mounts out of aluminum. I would like to know if any of you have made yours out of another material i.e. plastic, wood, etc.
Also, is there any rule stating that you cannot construct motor mounts out of another material? We've checked through the rules and haven't found anything prohiting it, but there may be technicalities we're not aware of.
Thanks for the help,
Team 950
Unread 09-02-2003, 00:07
RobDeCotiis RobDeCotiis is offline
FRC #1660
RobDeCotiis can only hope to improve
Send a message via AIM to RobDeCotiis
mount em in whatever u want.. as long as its not on the restricted parts list, ur fine. i dont think it'd be a good idea to mount them in jello tho, because you're going to have a lot of flexing in the shaft.. if you use a flex coupling, you'll be fine tho.
Unread 09-02-2003, 00:48
Thanks Rob.
Unread 09-02-2003, 12:45
Iain Iain is offline
Iain is an unknown quantity at this point
Well, we're using the plastic mounts that come with the drill motor - and it's about the only thing we haven't had trouble with yet.
Unread 09-02-2003, 20:28
If you mean the plastic collars that came with the drill motor, we're using those too, but those are too wide to fit onto our frame. I was referring to a separate piece that you fabricate to fasten those collars to your frame.
plastic hubs and drill motors Will Camisa General Forum 4 01-03-2003 00:03
What type of plastic is the Adam Y. Technical Discussion 1 28-01-2003 18:03
Plastic Retaining Rings Adam Y. Technical Discussion 9 15-01-2003 09:48
plastic boxes Suzy General Forum 6 12-01-2003 03:27
Plastic Spur Gears Joe Canavan Technical Discussion 2 25-11-2001 01:45
