Go to Post Free time? You mean the time it takes the code to build? - axiomofdarkness [more]
Unread 26-01-2003, 23:23
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
I'm curious where you're using the plastics Joe?
Personally, I would for sure never use them in a drive system. Maybe for pick-up or something...?
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 02-02-2003, 12:01
Lauren Hafford Lauren Hafford is offline
#0159 (Alpine Robotics)
Lauren Hafford is an unknown quantity at this point
Send a message via AIM to Lauren Hafford
hubs and bores
finding a 5/8'' bore: it's uber easy to drill out the center of a gear, especially a spur gear with a hub. but sprockets have hubs, just mount them in the lathe hub inwards in the chuck and put a drill bit in the tailstock. for drilling out steel i would run it reallly slowly. that's if you can't find cheap sprockets to your desired bore.
BTW, we have steel spur gears and turned off most of the hubs (so we can still have a setscrew) and the weight was almost cut in half. If that helps.
lauren
Unread 03-02-2003, 21:37
Dick Linn's Avatar
no team (Synergy)
Sprockets
It's all engineered, folks. Glass-filled sprockets of the correct diameter can work just as well as steel if you figure it out. Just don't count on a 10-tooth plastic sprocket if you have high torque and poor alignment and don't drive conservatively. It all depends...
On the other side of the equation, picture this. Last year, we had 60-tooth #35 chain sprockets that needed serious lightening to make weigh. I didn't like it, but I had to spend about 2 hours with a 4 1/2" angle grinder and a very thin cut-off wheel to gouge about 1 1/2 pounds of out of the solid steel "pancakes" because we had no access to a mill. Not fun and definitely bordering on the dangerous in trms of possible mishaps. The good part was that these were off-the-shelf go-kart parts that were really cheap. And the drive-train was completely reliable. No breakage, no spares, no hassle. And no chain tensioning during the regional or the final at Epcot.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 08-02-2003, 23:58
Mercutio Mercutio is offline
Atticus Finch Wannabe
#1213 (The Grobots)
Mercutio is on a distinguished road
Plastic... material of the future or angel of robotic death?
I'm seeing a lot of hostility towards plastic sprockets on this thread. I can't say I've ever seen plastic sprockets, but we are using a lot of plastic as a structural component on our robot this year. We haven't done any formal tests, but after trying to file it, bend it, break it, and punch a hole in it with a hammer, I got the impression that it's very strong. One definite advantage of plastic is that blocks of it can easily be formed into complicated-shaped parts. This is the first time we've ever used plastic, so stay tuned... if Team 1213's bot falls apart, you'll know plastic is no good! ^_^
"If we knew what we were doing, it wouldn't be called research, would it?"
—Albert Einstein
<X3 What can I do? You broke the tie wraps that were holding together my heart. ^_^
Unread 09-02-2003, 00:13
RobDeCotiis RobDeCotiis is offline
FRC #1660
RobDeCotiis can only hope to improve
Send a message via AIM to RobDeCotiis
I think you may be refering to gears made of pressed powdered metal like the old chiaphua gear cluster. If you want a good idea of how hard that thing was, try to grind it off. The lathe wouldn't even scratch it.
i had to saw through one of those.. by hand..it took me 45 minutes with a CARBIDE BLADE!!!
lord, that sucked royally
Unread 09-02-2003, 00:52
Maxzillian Maxzillian is offline
AKA: Eric H.
FRC #0935 (RaileRobotics)
Maxzillian is on a distinguished road
Send a message via AIM to Maxzillian
Another idea would be to make the teeth section steel, and then mount that to an aluminum hub.
Team 935 RaileRobotics Alumni: 2001-2004
Team 935 RaileRobotics Mentor: 2009-Present
Unread 09-02-2003, 01:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I was pondering that idea myself. It would work pretty well too. A system like this was just introduced in the bicycling industry. A steel braking surface for disc brakes is bolted to an aluminum carrier that then attaches to the hub. It saves quite a bit of weight, but im not sure how easy it would be to implement this in FIRST. It would take quite a bit of machining and a lot of work. I dont think it would be strong enough for drive sprockets either.
Cory
2001-2004: Team 100
2006-Present: Team 254
need help fast!!! Hubless 1/4 pitch sprockets Travis Covington General Forum 6 03-02-2003 18:44
modifying sprockets gail OCCRA 3 05-10-2002 12:13
Chief Delphi sprockets archiver 2001 23 24-06-2002 01:46
Re: Connecting hub sprockets to shafts archiver 2001 1 24-06-2002 00:20
Attaching the Gears and sprockets to the shaft archiver 2001 2 23-06-2002 23:18
