Go to Post "I don't have a cockroach in my presentation.... " I will remember this line forever. Thank you Autodesk. - Zyik [more]
Unread 05-12-2013, 16:05
mattachew12 mattachew12 is offline
FRC #3597
mattachew12 is an unknown quantity at this point
Re: LAN fine WiFi inoperable
I reset the router and the wireless IP address, disabled and unplugged my LAN connection, and also unplugged the connection to the cRIO, so as far as the router knows, it is just powered on for the first time and set to 2.4GHz. It still didn't show up as either dlink or 3597. Could it be a nameless "Other Network"? I tested those too as dlink and 3597 but they didn't work either. My computer connected to it last year so I know it is compatible.
Should it show up even if my IP address is bad, and I just won't be able to pass information on the next work, or will it simply not show up at all unless the wifi computer IP is correct?
Could it be the ethernet cable? I am using patch cables from both computer to bridge and from bridge to cRIO. I've been able to connect to the robot and enable it in the driver station though so I don't believe this is the problem. It seems most troubling that even as a complete reset, it won't show up at all.
Error 404-Signature Not Found
