Go to Post We're thinking of using static electricity to pick up the tubes. The programmers are trying to figure out how to make the robot shuffle it's feet on the carpet. - Tom Ore [more]
Unread 06-12-2013, 01:45
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Painting and Scheduling
We've recently been working to acquire powdercoating and anodizing sponsors, and have begun to realize that painting really does take a while. Parts have to be test assembled, cleaned, sent off to sponsors (or actually painted, if you can do that yourself), picked up, re-finished (if bearing holes or tapped holes got painted over, for example), and then re-assembled into the final assembly. Of course, this is all assuming that you never want to iterate that part of the robot ever again. I'm beginning to think that painting a fair fraction of the robot could potentially knock three to five days out of our schedule, much more than I would suspect most teams dedicate to it.
How do teams that paint much or all of their robot every year handle all this time in their scheduling? When is it typically done, how long does it typically take, and how do you make the call that an assembly works well enough as-is to be worth painting or coating? What are the logistical tricks associated with painting a robot during the season?
Finally, does anyone have any design/machining tips for parts that are meant to be powdercoated or anodized?
-Plutarch
Unread 06-12-2013, 01:55
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Re: Painting and Scheduling
Our sponsor who helps us with milling and lathe work actually powdercoats for us. I'm not sure what system they use but we drop it off after school and pick it up the next morning. Pretty quick process
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 06-12-2013, 02:22
the.miler's Avatar
the.miler the.miler is offline
taking a break
AKA: Miles Chan
FRC #0846 (Funky Monkeys)
the.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of light
This is one of the reasons why we just spray paint our parts; we make our parts, take them outside, prime, and paint them, and have them back within a few hours if we're in a real hurry. It likely beats the turnaround we would see if we powder coated. The other reason is that we haven't really explored powder coating yet, since we have a solution for making our robot look nice already in place.
Sure, the spray paint might wear and chip and the powder coating won't, but from a distance nobody will be able to tell the difference.
In terms of deciding whether something is worth painting; if it's not going to be iterated, it gets painted (drivetrain, superstructure). If we think it might go through some significant changes soon, we generally hold off a bit. For example, we didn't paint the collector until we knew it was going to work well enough for us to put it on the robot in the first place. Some parts of our robot remain unpainted, and that's also okay with us. All we need it to do is stand out on the field and look pretty, and as long as enough of the robot is yellow and black, the painting has done its job.
Just my take!
Member 846 The Funky Monkeys 2010-2014
Team 846 Highlights 2014
lynbrookrobotics.com
becauserobots.org
Unread 06-12-2013, 02:50
FRC #1836 (MilkenKnights)
Powdercoating an anodizing can take quite a bit of time out of your schedule. This is not even considering the fact that the company may not be running your color that day. However the benefits are good(sponsors really like it and it makes the robot look a lot more professional) so we continue to do it.
The biggest thing you can do to get around these negatives is a non-powdercoated practice bot. You can do all your testing and iteration on the practice bot and you do not lose any time. You then learn your mistakes and where you need to iterate. Only after all your iteration is done do you assemble the competition robot with your new knowledge. I find that anodizing is generally done on small parts so iteration on these parts isn't as important.
For the comp bot we generally try to send stuff off to ano immediately, and send stuff off to powdercoat as soon as we have a working practice assembly(this isn't always a rigid law. Drivetrain for example is sent off immediately. Individual parts are also sent off earlier than assemblies). Bolt patterns and planning ahead on parts that you think you will want to iterate allows this to work out pretty well.
Unread 06-12-2013, 03:12
Mr V's Avatar
Mr V Mr V is offline
FRC #5588 (Reign)
I've always wanted to ship out a bunch of stock to have it anodized before we mill it. I think it would look great if for example we did all the 1x1 tube in gold while the 1x2 was done in black and in either case the weight reduction holes would really pop in the raw aluminum silver. Yes it would require being a little more careful when clamping it in the vice for milling.
Years ago one of our then students and a couple of mentors did anodize the pieces for the competition robot before final assembly. However since they built the tanks themselves and they had a problem with them leaking the mentor got frustrated and tossed all the tanks and he has since left the team.
Unread 06-12-2013, 08:56
Gdeaver Gdeaver is offline
FRC #1640
Personally I like naked robots. My team disagrees. There always seems to be 1 more weld or process the painting interferes with.
Unread 07-12-2013, 01:46
dtengineering's Avatar
AKA: Jason Brett
I was always hesitant to paint or powder coat the aluminum parts of the robot. Occasionally... very occasionally, we would have to take a metal part to the machine shop at an event and ask them to weld it, or to weld something to it. Admittedly it doesn't take long to clean paint off a part... or even powder coat... but it does take time.
Of course we had not such concerns when we made the robots out of wood. Aniline dyes and lacquer were our blingy finish!
Jason
Unread 07-12-2013, 02:05
Jason
Your wooden robots are still some of my favorites, especially 2010!
Unread 07-12-2013, 03:24
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
We started powdercoating the robot in 2012 and it definitely adds ~3 days to the build process. But the result is worth it in my opinion. The whole team takes a lot of pride in a nicely finished product. The real trick is to find a powdercoater that will work with you on your timeline. Our sponsor, Classic PowderCoating, actually delivered some of our parts to us as soon as they were ready. He even ran out of gold flake while doing some of the pieces and drove to San Jose to pick up more that same day to finish the job.
Other things to consider is the 2-3 hours of filing/reaming bearing holes and such. It also adds 2-4 lbs.
Our week 6 schedule has our robot frame, wheels, and manipulator components ready to go to the powdercoater on Monday of that week. The powdercoater agrees to get it back to us no later than Thursday afternoon. We then do an all day/night session on Thursday-Friday assembling and wiring the robot to have it ready to scrimmage on Saturday (some assembly happens at the Scrimmage as well). Since we can't do much with a robot that is at the paint shop, our programmers/drivers are busy testing code and practicing on our first unpainted robot.
Unread 07-12-2013, 12:46
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
I'm hoping to add build-site powder coating this year with one of these:
http://www.eastwood.com/dual-voltage...arter-kit.html
and the old, ugly (but still functional) electric kitchen stove I just replaced.
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 07-12-2013, 13:35
Brandon Holley's Avatar
We anodized our bots from 2006-2012, and we really loved the look of it. We often did 2 batches of 2 colors a piece. We were fortunate enough to have sponsors able to turn the parts around in 2-3 days. Even still, with the cleaning, prep, etc, we ended up taking 4-5 days out of the schedule to do so.
Last year we built our own powdercoating oven. It took a decent chunk of effort, but it's been one of the best things we've ever done. The whole team is involved in the coating of parts, from cleaning, prepping, spraying the parts to prepping the oven and clean-up. We're able to go from raw material to CNC to coated part assembled to a robot in a matter of hours.
If you have the means, and really want to 'paint' your bots, its an awesome way to keep the timeline under control.
See some of these attached photos of the oven and a batch of parts we cranked out in a single day.
-Brando
ID:	15514  Click image for larger version
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 07-12-2013, 23:07
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Does anyone have any experience or insights into teams anodizing on their own? I've been doing a bit of research, and it appears to be difficult but not prohibitively so for teams to start their own anodizing setup.
-Plutarch
Unread 07-12-2013, 23:12
AdamHeard's Avatar
Lead Mentor
We spent a good deal of time researching it, unless you have a huge surplus of labor it's better to just get a sponsor to do it.
An entire robot's worth of anodizing (for most teams) is only $100-200 as well (assuming just color, nothing hard plated) so it's cheaper to just pay to get it done.
Unread 07-12-2013, 23:17
DampRobot's Avatar
Physics Major
AKA: Roger Romani
My main thought is we could get better turnaround times this way. The frame can be out for a few days for PC, but if a part has to be anoed, you generally want it pretty fast to assemble and test. Depending on the sponsor, the wit might be too long.
-Plutarch
Unread 07-12-2013, 23:19
AdamHeard's Avatar
Lead Mentor
San Jose has a lot of anodizing shops, if you're just looking to get something done black I'm certain you can find many with same day service.
We've had several places anodize for 973. All in LA, San Jose or Fresno. They drive a truck/van all the way to SLO 3 days a week. We get 2 day turnaround on everything.
I'm certain you can get next day up there.
