Go to Post The big lesson we learned ... our past does not limit our future, that superior attitude will beat out big budgets. - [more]
Unread 07-12-2013, 02:29
Kevin Ray's Avatar
Kevin Ray Kevin Ray is offline
None #0329 (Raiders)
Kevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to beholdKevin Ray is a splendid one to behold
Re: Anybody hear of this - 3D printers for every FIRST team
On the smooth side of the build plate is a sheet of Kapton which helps the filament adhere to the plate (at least is on the Replicator 2X). There are some other tricks for removing a build from the deck. Try holding a can of compressed air upside down and letting the cold air "shrink" the build momentarily. It usually pops right off. Also, you may not have to do a lot of rafting (building a stable adhering surface on the build plate) for the Replicator 2X that you might have to do for other printers because of the heated build plate.
Many downloads from Thingiverse (warehouse of 3D models) are made on other brands of printers and you may have to make adjustments to the printer settings prior to hitting "print".
Finally, I can't wait until there is a plethora of FIRST-specific models out there on CD's white pages or Thingiverse for teams to share. There are literally hundreds of parts that can go on a bot that can be printed and I think this year will bear that out. I just hope the Makerbot will accept the carbon fiber Pla from the Proto Plant Inc. guys. That could open a lot of doors.
_____________________________________________
Last words before magic smoke appears: "There, that oughta work!"
2016 Utah Regional- Engineering Inspiration
2016 Utah Regional- Dean's List Semi-Finalist- Ed O'Connor
2016 Utah Regional- Dean's List Semi-Finalist- Emily Ferrari
2016 Utah Regional- 3rd seed
2016 SBPLI Regional- Finalist, 6th seed
2016 SBPLI Regional- Gracious Professionalism Award
