Go to Post If your heart is racing and you feel a little nervous, then you're on the right side of the alliance station wall!;) - David Brinza [more]
Unread 15-10-2013, 10:19
Bpk9p4's Avatar
Bpk9p4 Bpk9p4 is offline
FRC #1756
Bpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant futureBpk9p4 has a brilliant future
Labview Version Control
Has anyone done version control with labview? If so how have you done it and has it been worth it for your team?
Unread 15-10-2013, 11:30
Re: Labview Version Control
We have used CVS for version control with LabVIEW for several years. We used Tortoise CVS as the CVS client. I posted some of our lessons learned here: http://www.chiefdelphi.com/forums/sh...60&postcount=5
Even though version control with LabVIEW is a little harder then a text based language, it's still worth it, even if you only use it as an integrated backup solution.
Unread 03-12-2013, 19:28
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Even professionally, we use a Subversion server with the TortoiseSVN client for SCM (Software Configuration Management) of our LabVIEW software. National Instruments has a (semi) detailed white-paper here: http://www.ni.com/white-paper/4114/en/
Good luck!
Unread 04-12-2013, 09:34
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Perforce is a great tool that's used in many large programming companies including Microsoft and Riot Games. NI even has a neat pdf showing how to set it up and explaining how it works here. I plan on using this with my team this year, as our code is getting lost and messed up due to multiple programmers, haha.
Per Audacia Ad Astra
Unread 04-12-2013, 11:36
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
We also use Perforce here at National Instruments for our internal development.
Doug Norman
Unread 07-12-2013, 20:20
hzheng_449 hzheng_449 is offline
AKA: Harrison Zheng
FRC #0449 (Blair Robot Project)
hzheng_449 will become famous soon enough
Our team has used SVN, but this offseason we tried rebuilding our 2013 code, but with GitHub, which is what we're planning on using this build season.
Unread 10-12-2013, 22:24
gnunes gnunes is offline
FRC #1391 (Metal Moose)
gnunes has a spectacular aura aboutgnunes has a spectacular aura aboutgnunes has a spectacular aura about
Attached are a pair of VIs that can provide a poor person's approach to backup and version control. It is not a substitute for real version control, but it requires no server or additional software.
If you are looking for something "no frills" and can work around the limitations, you might find them useful.
-GN
Unread 11-12-2013, 09:21
Originally Posted by gnunes View Post
Attached are a pair of VIs that can provide a poor person's approach to backup and version control...
I didn't look deeply into them, but I didn't see anything that couldn't be done using a simple .cmd "batch" file. Are they doing something special that I didn't notice?
Unread 11-12-2013, 13:49
When I say 'just do it with a simple .cmd "batch" file', my scaly dinosaur hide immediately comes into focus and the students start scanning the sky for the meteor that is about to take me out. Well, some students. Most simply assume that I have for some reason chosen to start speaking in Serbo-Croatian.
But seriously...you are correct. My programs offer no sophistication, only convenience and ease of use (they auto-name the archives, offer an easy option for putting a copy of the archive onto a flash drive, etc., etc.)
