Go to Post When I got home from work my facebook wall had exploded with people chanting the names of dead scientists. Did someone say culture change? :cool: - Ian Curtis [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Unread 07-12-2013, 16:26
Re: 6 CIM Drivetrains... What's Your Experience?
Originally Posted by Nate Bloom View Post
Even so, you're still limited to 40 amps per CIM...
The Snap-Action 40a Breaker Spec. overload ratings:
150 % overload = 3.9 - 47 seconds
175 % overload = 2.2 - 9.2 second
200 % overload = 1.5 - 3.9 seconds
250 % overload = 0.8 - 1.8 seconds
300 % overload = 0.5 - 1.1 seconds
400 % overload = 0.3 - 0.6 seconds
500 % overload = 0.2 - 0.3 seconds
Unread 07-12-2013, 16:27
What's the math for a traction limited drive?
If:
- the wheels are all the same type and diameter and are chained (or belted) together on each side, and
- you are powering each side with a single gearbox with N CIMs, and
- you assume that traction force = normal force * coefficient of static friction (where coefficient is a constant), and
- the center of mass lies along the vehicle longitudinal axis,
then:
A = [(4*D/G*Istall*mu*W)/(eff*Tstall)]/N
where:
A = amps per CIM required to break traction and spin the wheels
W = weight (lbs) of vehicle
mu = coefficient of static friction
D = diameter of wheel in inches
G = the total speed reduction gear ratio from motor to wheel (including sprockets/pulleys)
eff = drivetrain torque efficiency fraction
Tstall = CIM spec stall torque (oz_in)
Istall = CIM spec stall amps
Unread 07-12-2013, 16:30
Nate Bloom's Avatar
Nate Bloom Nate Bloom is offline
FRC #1410 (Kraken)
Nate Bloom will become famous soon enough
Just out of curiosity, how do you estimate the drive train torque efficiency?
"Simplify and add lightness." - Colin Chapman, Founder of Lotus
2014 Colorado Regional Finalists (2996, 1410, 662)
2014 Utah Regional Quarterfinalists (1410, 1339, 3669)
2013 Colorado Regional Finalists - Entrepeneurship (2996, 1410, 662)
2013 Utah Regional Quarterfinalists - Imagery (3374, 1410, 3405)
2012 Colorado Regional Quarterfinalists - Imagery (1410, 1619, 3200)
2011 Colorado Regional Quarterfinalists (443, 1410, 1245)
Unread 07-12-2013, 16:40
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
An equally pertinent question might be, what steps can a team take to minimize drivetrain mechanical power losses? There are many factors to consider, including alignment, lubrication, fits/clearances, materials, etc.; however, the concept is simple. If it rolls straight and easily, the losses are low. Many of us learned this as Cub Scouts building pinewood race cars.
80% to 85% is a figure often "plugged in" when using drivetrain calculators (e.g., JVN) -- however, some teams build drive trains that are better than that, and quite a few build them worse.
One good test to try is measuring the free current of the completed drivetrain (wheels up).
Richard Wallace
since 2003
That's the 64 Thousand Dollar Question.
Unread 07-12-2013, 16:48
That is probably a good test to determine relative efficiency (e.g when trying to tune the alignment, chain/belt tension, etc of a drivetrain), but how would you tease the absolute efficiency from just that one piece of data?
Unread 07-12-2013, 16:56
I don't think you can do that. The free current test is useful for determining if 'tweaks' are moving in the right direction. It cannot capture the effects of losses that depend on loading, particularly those that become more significant at higher loads.
Richard Wallace
since 2003
Unread 07-12-2013, 18:29
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
We ran a 6 CIM drive this year and it was okay but we geared it pretty high to be able to keep up with other robots. (5.33:1 than 26:22) with 8 versawheels. We could hold our own in pushing matches but we were always on the edge of brown/black outs. We blacked out once at Razorback and browned out in our first match at IRI other than that our driver kept it with in it's limits.
It was a fun experience and it helped us win a few matches but we will almost certainly be using 4 CIMs and Ball shifters this year instead. It wasn't worth the fear of possibly popping the main breaker in any given match.
Unread 08-12-2013, 08:26
philso philso is offline
FRC #2587
Originally Posted by SoftwareBug2.0 View Post
We have used six CIMs in our drivetrain. However, our drivetrain never used more than four of them at full power at once which probably helped avoid any current/voltage problems. No special software was needed.
What do you mean by this?
Are you delaying the start up of one of one, or more, of the motors on each side to spread out the current peaks?
Unread 08-12-2013, 08:34
FRC #2587
This would require a calibrated "rolling road" dynamometer and instruments to measure the instantaneous battery voltage and current and the load that the dynamometer was applying. The effect of wheel spin would could be approximated if the dynamometer rollers were wrapped with the proper type of carpet.
Maybe your local race shop might be able to help out
Unread 08-12-2013, 09:40
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
We ran 6 CIM motors through this VEXpro gearbox at 6:1 reduction, the standard KOP belt system, and 4" wheels. Worked great for us, no issues whatsoever all year. When we increased the weight up to 120 + 20 for bumpers + battery and installed traction wheels, the motors gave us that little bit of oomph that we needed to power through to the feeder station. If we were in more sustained pushing matches, we would have found ourselves more at risk of breaker tripping.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
Unread 08-12-2013, 13:57
SoftwareBug2.0's Avatar
AKA: Eric
FRC #1425 (Error Code Xero)
We didn't have any delays to spread out current peaks. We used six CIMs and each of our wheels was powered by two CIMs, so we had three wheels. Our drivetrain would have just been very hard to control if we had turned all the motors on full at once because it would have wanted to spin very quickly.
http://www.youtube.com/watch?v=oMBTmfBnjsc
I was wondering whether people would read closely enough to see that what I had to say didn't make sense for a typical 6-wheel drive.
Unread 08-12-2013, 18:51
Oblarg Oblarg is offline
AKA: Eli Barnett
Find a surface on which you know the CoF of the wheels to reasonable accuracy, get a high-speed camera (or accelerometer), and measure the acceleration/current draw of the robot running at full power pushing various objects whose dynamic friction on that surface has been measured?
Not perfect, obviously, and rather time-consuming, but it should give you something to compare against theory.
"The breakfast of champions!"
Unread 08-12-2013, 19:56
drwisley's Avatar
drwisley drwisley is offline
FRC Coach
AKA: Dave
FRC #1756 (Argos)
drwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant futuredrwisley has a brilliant future
I use the no load losses from test stands, which we can derive from the current, and add 1% per gear mesh under load. I have some powertrain industry experience to correlate this practice from. This is a good starting point for shift points. Although the 6 CIM rimpull calc's I have put together don't require shifting.
Unread 08-12-2013, 20:06
Here's the theory to compare it to.
Adjust Kro, Krv, and Kf until the model matches the test data.
