#16
Re: Omni vs Mecanum CoF ?
The dynamic CoF is interesting for two reasons. First, I am trying to predict where the transition to/from traction limited will occur (possibly not of practical importance). Second, many teams seem to depend on the wheels slipping during a pushing match (or drive into a wall) to limit the motor current. Four CIMs each drawing a stall current of 133A will obviously pop the breakers. The question is, what gear ratio gets the current to about 40A per CIM when driving into a wall. I believe we need the dynamic CoF for that calculation. This is true for traction wheels as well as holonomic wheels. |
#17
I guess I agree with Oblarg that there is minimal difference in acceleration. I tried my drag race predictor (attached) for both drives and they are fairly close (would be even closer with non-standard gearboxes). However, I believe if both were in a pushing match, the Omni would still have a 20% traction advantage.
Omni 30deg, 12.76:1 Vfinal=11.58FPS, Accel= 28.6ft/s^2, T5ft=0.70s, T15ft=1.57s Mecanum 0deg, 10.71:1 Vfinal=11.94FPS, Accel=27.4ft/s^2, T5ft=0.67, T15ft=1.52s |
#18
I'm still interested in how he did the calculation, regardless. |
#19
Well, this is embarrassing: I can't find the scratch paper I did this on earlier, and I'm differing by a factor of two upon repeating the calculation. At any rate:
We'll omit the efficiency figure for the calculation; you can multiply by an estimate at the end if you wish. Let's round up to 160lbs, so we have 40lbs per wheel. Assume all weight is distributed equally among the wheels. CoF is 1, so our maximum friction force from a single wheel is 40lb. Let Wf be the free speed of a CIM, and Ts be the stall-torque of a CIM. Say our drive is geared to a top linear speed S, with effective stalled-torque-at-wheel T. Let our wheel radius be denoted r (we need not specify a value, as it is divided out later). Then (Wf * 2 * pi * r)/S = T/Ts. Let T/r = 40lb, i.e. the force to stall our wheel is precisely equal to the available friction force. Then we have (Wf * 2 * pi * r)/S = (40lb * r)/Ts, which yields S = (Wf * 2 * pi * r)*Ts/(40lb * r). Our wheel radius term cancels, leaving S = (Wf*2*pi*Ts)/(40lb). If you plug in and calculate, you end up with ~25 feet per second, which is a factor of two off from what I got last time. For the life of me, I can't find where this calculation is wrong, though the result is much more surprising than what I had previously believed, and does not really mesh with my experience of wheel slippage while driving... Last edited by Oblarg : 09-12-2013 at 16:55. |
#20
I do not know if this really helps, but my Vex Omnibot is able to climb walls (and end up flipping itself over) because it has a very high traction. To me, I think that omni wheels give a better traction than mecanum because it is pulling apart the carpet in the front and pushing it together in the back so it seems like the wheels would be a lot more grippy. Also, as I have noticed, omni is great for turning in place. This may be the size causing this, but I find that Omni is more responsive than mecanum! I can change the direction instantly and I won't have to wait for the rollers to stop coasting. However, this could be because of the robot size differences, and thus the inertia!
#21
It would probably be simpler to create a formula for the required gear ratio to slip the wheels at stall torque. (Gear ratio is lacking in your above formula). The formula would be as follows, Assuming 4 wheels and 4 CIMs; Desired drive force = (Gear Ratio * Stall torque)/Radius Desired drive force/(stall torque * radius) = gear ratio Once you have the required gear ratio you can then calculate the speed you would achieve. Using the numbers you provided, this would give a gear ratio of about 4:1, with a top speed of ~23FPS, assuming 0 inefficiencies or losses. However, in the real world, with losses and FRC batteries, the maximum speed to slip the wheels is going to be substantially lower. Last edited by AlecS : 09-12-2013 at 17:36. |
#22
Equate ratio of free speed of CIM to free speed of wheel to the ratio between the stall torque of the motor and the stall-torque of the wheel. Relate stall-torque of wheel to force needed to stall the wheel. Plug in and solve for free speed of the wheel. The factor of 2*pi comes from the fact that we are specifying a linear velocity, not a rotational one. Last edited by Oblarg : 09-12-2013 at 17:39. |
#23
During design it is important to know not only "what" occurs, but "why." When you mention anecdotal things that you've seen, you're mentioning "what" happens, but not "why." Often, people don't even see the truth of what is going on. People have an idea in their head of what is supposed to happen, and as such their observations fill in the blanks to make it true. (This is called confirmation bias.) We can't always trust ourselves to actually make good observations. This is another reason for truly trying to understand "why" things behave like they do. I've noticed you've made a few posts where you make blanket statements based on anecdotal observations. You need to be careful when you do this. It might be better to really "dig in" to the physics, and try to get to the bottom of how things really work. It is REALLY cool, I promise you. It will change your view of the world.If you're interested in adding some depth to your expertise... This is a cool thread where some really sharp people are debating the vector physics behind Mecanum Wheels vs Omni-Directional Wheels. You should "search all posts" by Ether, and read some of the things he's linked and discussed. In addition, feel free to ask lots of questions of the veteran designers on this forum; they'll be happy to help you out (since they probably started in the same place you did). Regards, John |
#24
Ah, I think I see why I was confused, The initial equation was flipped.
Intial Eq: (Wf * 2 * pi * r)/S = (40lb * r)/Ts Eq: S/(Wf) = (40lb * r)/Ts This puts actual speed above free speed, and actual torque above stall torque, like you described. The previous version was not giving useful numbers, this one does. You also need to do some unit conversion there, If use Stall Torque in in/lbs (21.5); S = (Wf/(40lb/Ts))*2pi)/60/12 This equation gives ~23FPS, same as what I got above. This number would appear correct, assuming 0 losses and perfect current supply. Last edited by AlecS : 09-12-2013 at 18:10. |
#25
![]() Well, looks like I was wrong the first time through about a week ago. I figure I probably had a radius in one part and a diameter somewhere else, or similar. |
#26
For one-CIM-per wheel: amps=(5760*Istall*mu*V*W)/(pi*eff*Sfree*Tstall) or V=(pi*amps*eff*Sfree*Tstall)/(5760*Istall*mu*W) where: amps = current required to slip the wheel So, plugging in Oblarg's numbers: amps=(5760*133*1.0*25*40)/(pi*1.0*5310*343.4) = 133.7 You're not going to get 133.7 amps in each of 4 motors, so if you gear for 25 ft/sec you definitely will not slip. Let's try some more reasonable numbers and try again: mu=1.0 V=12 W=37.5 eff=0.8 amps=(5760*133*1.0*12*37.5)/(pi*0.8*5310*343.4) = 75.2 Will the wheels slip? Well, 75 amps per motor times 4 motors is 300 amps. If your battery is strong your wiring is in good shape and the CIMs aren't too hot you might be able to push 300 amps thru the 4 CIMs. Let's try V=10: amps=(5760*133*1.0*10*37.5)/(pi*0.8*5310*343.4) = 62.7 OK, maybe that will slip. Last edited by Ether : 09-12-2013 at 18:41. |
#27
You're welcome.
Attached is the derivation of the formulas. Last edited by Ether : 10-12-2013 at 16:19. Reason: cleaned up the attachment a bit |
