Go to Post Remember to have fun! That's what the FIRST experience should be for you- a lot of fun while doing a lot of learning. - smurfgirl [more]
Unread 09-12-2013, 17:10
samn122 samn122 is offline
FRC #0334
samn122 has a spectacular aura aboutsamn122 has a spectacular aura about
Gyroscope Not Returning Degrees
We're programming a gyroscope on the robot and we're not getting a readout in degrees. The sensitivity is set to 0.007 (as referenced in the manual), the gyro is connected correctly and mounted on the robot. The readout we get is also not consistent because it decreases while stationary and we don't think it's drift. We tested sample code and read the manual but we're still having a problem.
Unread 09-12-2013, 18:45
Re: Gyroscope Not Returning Degrees
How is it connected?
Why don't you think it's drift? How fast is it decreasing? What does it do when you rotate the robot?
Please post the code you've tried.
Unread 09-12-2013, 21:43
FRC #0334
The rate header is connected to the analog breakout on port 1. We followed this guide from AndyMark.
The values it returns are inconsistent and simply unusuable. We are getting decimal values and after turning the robot a couple of times there would be no significant change. Sometimes it would jump and start increasing in the positive direction and go on indefinitely until the program is stopped. We don't think it's drift (or maybe it might be?) because we don't observe the values decreasing or increasing by a small margin. I will post a screenshot of the values on my next reply.
The code we're trying is from Team 2945, found on the fourms. We modified it a little.
 package com.github.manitourobotics.gyroscopetesting;
import edu.wpi.first.wpilibj.AnalogChannel;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.command.Scheduler;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import edu.wpi.first.wpilibj.smartdashboard.SmartDashboard;
public class GyroscopeTesting extends IterativeRobot {
    public void robotInit()
    AnalogChannel gyroChannel = new AnalogChannel(1);
    Gyro gyro = new Gyro(gyroChannel);
    public void teleopInit()
        gyro.reset();
    public void teleopPeriodic()
        gyro.setSensitivity(0.007);
        double gyroAngle = gyro.getAngle();
        SmartDashboard.putNumber("Gyro angle", gyroAngle);
        System.out.println("Gyro Angle: " + gyroAngle);
        Scheduler.getInstance().run();
Unread 09-12-2013, 22:57
What voltage do you measure with a multimeter between the rate pin and ground? It should be approximately 2.5v.
I like the LabVIEW gyro wiring diagram (attached), as it's a little more clear which wire goes where on the analog breakout.
Unread 10-12-2013, 13:04
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
I don't have the wpilib source avaialble, so I can't check to see if this should make any difference at all, but is there a reason you're setting the sensitivity repeatedly (in teleop periodic)?
The following is essentially what we've done every year with the gyro:
    Gyro gyro;
    public void robotInit()  {
        gyro = new Gyro(1);
        gyro.setSensitivity(0.0070);
        gyro.reset();
    public void teleopInit() {
    public void teleopPeriodic() {
If that doesn't work then I'd start looking at wiring, or where I think Joe was heading with the voltage check on the rate pin, the sensor itself. The only time I've had a problem with the sensor though is when it was run over by the robot, which has happened more than once.
http://team2168.org
Unread 10-12-2013, 20:22
FRC #0334
Thanks for the replies! After testing the gyro with a multimeter and on another cRIO unit, we discovered that the analog breakout was faulty and replaced it with another one. The gyro is working and we're getting a responsive and usable readout.
Unread 10-12-2013, 20:38
Thank you for reporting the resolution of the problem. That's great forum etiquette. Reps to you.
