Go to Post If a kid was in FIRST and no one was around to see it, do they still get inspired? - Katie_UPS [more]
Unread 18-11-2013, 05:27
tilky's Avatar
tilky tilky is offline
AKA: Ryan Thielke
FRC #3137
tilky is an unknown quantity at this point
Creating a Joystick-recognized Device
While my question is not relevant to FIRST, I'm hoping that somebody here might know the answer. I need to find a way to create my own joystick-recognized device, one that only has buttons. I know this is possible with microchips such as the Cypress that is used for the DS IO, but I wanted to keep it as cheap as possible. After doing some research, I came across an AT90S2313 microcontroller that is supposed to do the job. Did anyone else do this before and know of a good microcontroller to use? If not, can someone give a little insight as to the pin abbreviations used in the attached photo? Thanks in advance.
Unread 18-11-2013, 08:37
JCharlton's Avatar
JCharlton JCharlton is offline
AKA: JC
JCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to beholdJCharlton is a splendid one to behold
Re: Creating a Joystick-recognized Device
You might find this does what you're looking for?
http://www.u-hid.com/home/index.php
"There is no problem so bad that you can’t make it worse." - via Chris Hadfield
Unread 18-11-2013, 08:49
Mr. Rip's Avatar
Mr. Rip Mr. Rip is offline
FRC #1477 (Texas Torque)
Mr. Rip is a name known to allMr. Rip is a name known to allMr. Rip is a name known to allMr. Rip is a name known to allMr. Rip is a name known to allMr. Rip is a name known to all
This has all the information about your chip.
http://www.atmel.com/Images/doc0839.PDF
Mr. Rip
Texas Torque
Unread 18-11-2013, 10:30
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
You can make a USB device basically 3 ways and expect some standard operating system support:
Emulated serial
HID
Mass storage
Since mass storage is unlikely to matter let's just skip that.
So that leaves emulated serial and HID.
Emulated serial can easily be done with PIC or Atmel USB interface equipped MCU like the PIC4550. It works on Windows, Mac OSX, Linux and BSD. Generally no magical drivers are required to make it work. So basically for the beginner that mode of operation is the easiest to grasp and get results with. It might limit your performance to 200kbps. However for a controller that's probably irrelevant. BTW this mode of operation is how BASIC Stamps and Parallax Propellers are debugged and how many bootloaders get software into an MCU.
Most joysticks work in the HID mode (as mentioned above). This mode requires more effort to create. Generally speaking a shortcut is buying a prefabricated module or software layers that handles the oddities you might encounter for you (instead of reinventing the wheel). This can add cost and HID device support is not universal. Certain simple peripherals like keyboard and mice are well tolerated. However more complex devices can lead you into driver development.
You can get a board from Olimex with the PIC4550 already mounted on it:
Olimex direct
I recommend this board. I know it works just fine. There are American distributors that can ship from here.
Unread 29-11-2013, 22:41
calvin909090 calvin909090 is offline
FRC #0192
calvin909090 is an unknown quantity at this point
What we've done previously for button inputs is just take apart one of our attack joysticks, isolate the circuitry, and attach our own buttons to it, bypassing the buttons on the joystick itself. You get 10 buttons, and 3 analog inputs if you want them.
It's probably cheaper than a custom microcontroller solution (I see a refurbished attack 3 on ebay for $16), and there's no coding involved.
Unread 29-11-2013, 23:02
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
The Teensy 3.0 has built in HID and joystick emulation in a small and convenient package
2016: FRC 865 Mentor
Unread 29-11-2013, 23:22
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Spectrum even released a white paper about using the Teensy 2.0
http://www.chiefdelphi.com/media/papers/2666
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 30-11-2013, 13:30
s1900ahon s1900ahon is offline
AKA: Scott McMahon
FRC #2468 (Appreciate)
s1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant futures1900ahon has a brilliant future
You might consider the use of the following devices donated to FIRST Choice (I know yours is not a FIRST project but you can pick these up really inexpensively at DigiKey or Mouser). We'll be providing a pre-built binary for general use and releasing the source code for it so that some teams (or folks like yourself) may modify it for their specific purposes.
http://www.firstchoicebyandymark.com/en/fc14-011
David Yanoshak (dyanoshak) will be posting additional details of this and some interfacing options in the near future (a couple of days from now).
Unread 01-12-2013, 11:59
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
Just posted here: http://www.chiefdelphi.com/forums/sh...hreadid=122587
-David
Unread 09-12-2013, 22:02
adciv adciv is offline
One Eyed Man
FRC #0836 (RoboBees)
I found out about estoprobotics the other day, this may be what you need.
https://www.estoprobotics.com/estore...d&productId=33
Unread 09-12-2013, 22:54
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
We've disassembled a gamepad and connected other switches and potentiometers on a custom control box to the gamepad circuit board. It works pretty well and is as inexpensive as whatever joystick or gamepad you use.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 09-12-2013, 22:56
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
Do you have the model you used?
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 09-12-2013, 23:14
Custom User Title
AKA: Cal
We used the Logitech F310 gamepad, but any USB game controller should work.
Unread 10-12-2013, 18:28
rkoripalli's Avatar
rkoripalli rkoripalli is offline
AKA: Rohan Koripalli
FRC #3735 (Klein Bots)
rkoripalli is an unknown quantity at this point
You can use a Teensy with the arduino IDE to make a USB controller, if you would prefer to use an arduino board, the arduino due and leonardo should also be compatible with the USB Keyboard/Mouse libraries.
