Go to Post amazing stuff. - Specialagentjim [more]
Unread 10-12-2013, 19:59
nrogals nrogals is offline
None #3173
nrogals is on a distinguished road
CIM Motors reusable?
So we have about 11 older CIM motors. My team wants to know if it would be better to use our older motors for the time being until we get new motors later in the season, or if we should get the motors immediately. Is it really that bad to use older motors for a little bit? Would anything terrifyingly horrible happen to our prototypes? I believe that they are 2011 and 2012 motors.
Unread 10-12-2013, 20:01
yash101 yash101 is offline
AKA: null
Re: CIM Motors reusable?
I think you may have a tad lower performance, but CIMs and MiniCIMs shouldn't have the wear that evident. Just avoid reusing BAG motors. They don't have a very long lifespan because the bearings get destroyed by the high RPM, (14,000RPM). Those are the main motors that I have played with in the one year I have been of FIRST!
Unread 10-12-2013, 20:05
magnets's Avatar
magnets magnets is offline
You might see a slight performance gain in newer CIMs, and the older ones may be slightly prone to failure, but you'll be fine. Our team routinely uses CIMs from at least 6 years ago and older.
Unread 10-12-2013, 20:06
If they're the same part number, go for it. I haven't seen any apparent drop off in performance from a CIM in storage.
Unread 10-12-2013, 20:07
BobbyVanNess's Avatar
BobbyVanNess BobbyVanNess is offline
AKA: Bobby Van Ness
FRC #0020 (The Rocketeers)
BobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of lightBobbyVanNess is a glorious beacon of light
CIM motors are the most durable motors allowed in FRC. We've definitely gotten some mileage out of them, and I've never actually seen one go bad. Usually we'll use old CIM motors on our practice bot when we run out of new ones. I've never felt any noticeable difference in power on the drivetrain, where they're primarily used. This past year, a 2008 CIM motor actually wound up on the flywheel for our 2013 competition bot, and it worked absolutely fine all year. Though we made sure to peel the 2008 sticker off at our first regional in case any nosy pit scouts were to take notice
2016 TVR Finalists, FLR Champions, Carver Sub-Division
2015 TVR Finalists, Carson Sub-Division Champions, IRI
2014 TVR Champions, FLR Champions, Archimedes Division, IRI
2013 WPI Regional Finalist, Connecticut Regional Champion, Archimedes Division, IRI
2013 Championship and IRI Talent Show winner
2013 - 2014 Driver: 82-43
Lead Strategy Mentor: 32-15
Unread 10-12-2013, 20:51
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I will second that. CIMs are some to the most durable motors I have worked with in any application. However, like any motor, they can be damaged by overheating. See this thread for a good example.
Also see this other thread for some details on how CIM motors heat up when loaded to their maximum mechanical output power.
As many long time FRC participants can attest, CIM motors typically last several seasons unless severely abused. Measuring their free current is an easy way to detect such abuse. Typically that will be about 3 Ampere when first started and will reduce to about 2.5 Ampere after running for a few minutes -- friction reduces a bit when the bearings warm up.
Richard Wallace
since 2003
Unread 10-12-2013, 20:56
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
I'd say go for it. The only CIM I've seen die was stalled while hooked directly to a battery with a prototype that needed more torque than the ungeared CIM was willing to provide. Needless to say, there was quite a bit of magic smoke that day.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 10-12-2013, 20:58
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Unless you have some reason to believe they have been damaged by severe over-heating, there is no reason not to use them again. Their useful life is far greater than the mileage seen in most FRC seasons.
Unread 10-12-2013, 21:29
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
Can anyone provide some evidence to this? I have never heard a report about BAG motor bearings failing. And would be interested to see what situations caused these issues?
Unread 10-12-2013, 21:40
AKA: null
Our shooter BAGs kept failing. We took a couple apart and the bearings were shattered, and looked partially burnt!
Unread 10-12-2013, 21:48
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
... how'd you mount them? Did you direct-drive them and not support the shaft? If this is the case, I can't claim I'm surprised...
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 10-12-2013, 21:51
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Please avoid making generalizations based on just your experience. Just because you had some motors fail does not mean that the entire line of motors is bad. There are many factors that could contribute to a motor failing such as how you use it. I highly doubt that the designers would use bearings that are rated under the RPM of the motor.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 10-12-2013, 22:13
The likely cause of the bearing failure was explained to him in an earlier thread but he seems to have ignored it:
BAG motors have such a high RPM that they self-destruct their internal bearings.
Originally Posted by stinglikeabee View Post
I doubt speed was the root cause of the BAG motor failure. Improper side-loading on the bearing due to a shaft-mounted shooter wheel or an overtensioned belt was likely a root cause if the bearing itself failed.
Unread 10-12-2013, 22:16
AKA: null
No. I did read that post. I just haven't replied to it yet. We have a versa-planetary gearbox. I believe that those are built for motors like the BAG motors. It could be side-loading, but that wouldn't cause motor problems because doesn't the typical gearbox separate the motor from the drive-wheel?
Unread 10-12-2013, 22:20
Seriously? That was 2 and a half weeks ago... during which time you have made 200 posts.
As a general rule, if you haven't made the effort to discuss failures with the supplier to understand why the failures occurred -- especially in the case of products from major FRC supporters such as VEX -- please don't use this forum to bad-mouth their products.
