Go to Post The code is hopefully pretty self-documenting, but I haven't had time to comment it (kinda trying to build a robot at the moment). - RyanCahoon [more]
Unread 11-12-2013, 08:30
yash101 yash101 is offline
AKA: null
Re: CIM Motors reusable?
Originally Posted by luckof13 View Post
Do you have any evidence to back up your arcing claim? Many brushed DC motors achieve speeds much greater that this, including FRC motors. See the 2013 Motor Performance Data sheet.
If you had you shooter wheels directly attached to the output of the gearbox, I could see the side loads from the discs being shot effecting the motor.
I have a feeling that that may actually be the problem, though it seems unlikely. When a frisbee is being shot, it will put a force on the wheel, causing the motor to be sideloaded. That was partially our design, because the compression in the disks helps push them get accelerated better!
Anyways, I (and many others) are done with talking about THIS bag motor failure!
