Go to Post If we all keep our "secrets" about our robots, the rest of us don't learn as much. - Rick TYler [more]
Unread 08-02-2003, 23:44
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
RoboEmu 1.11beta1
To commemerate the 790th download (that's an average of once per team!) of RoboEmu 1.10, I bring you RoboEmu 1.11.
Like 1.10, I'm releasing it here first to get a little feedback before turning it loose on the community as a whole in order to save headaches for both myself and the endusers.
Anyways, I think you're going to like the new version, as it finally supports all the operators, both unary and binary. In addition, I took almost all of the suggestions I got last time around and implemented them. Here's the changelog:
Fixed LOOKDOWN
Fixed ABS
Added support for REV, SQR, DCD, NCD, SIN, COS
Added support for //, **, */, DIG, REV
Added match mode (15s autonomous then 1:45 normal)
Added parsing of $STAMP directive--only need to open slot 0 now
Added ability to minimize
Added ability to open project files from command line
Added check for 26-byte limit
Added file freshness check--will reload files if needed
Added '!dump directive
Changed UI to have a pause toggle instead of two menu items
Moved recent file list to registry, where it belongs
As always, I'm looking for bug reports, logic errors, or new feature suggestions as well as anything else you want to send me.
--Rob
Unread 09-02-2003, 01:50
guzugi's Avatar
guzugi guzugi is offline
guzugi is an unknown quantity at this point
Send a message via AIM to guzugi
VERY COOL!!!
do you have to src available?
Unread 09-02-2003, 09:11
FRC Key Volunteer Trainer
AKA: CrazyNate
Out of curiosity, did you correct the action of comp_mode? Per update 11, 1 now means disabled...
Nate Smith
nsmith@smythsoft.com
Unread 09-02-2003, 11:34
Originally posted by guzugi
VERY COOL!!!
Yes, RoboEmu is open-source, GPL'd software. I didn't post the source for 1.11beta because it is a little on the big side and I didn't really want to waste CD's space. If you want the source for version 1.10, it's available at my website, http://www.robbayer.com/software.html. Or, if you want the 1.11beta1 source, I can send it to you later tonight.
Oops, kinda forgot about that. I'll do it for the official 1.11 most definately. Thanks for the reminder.
Here's a few questions I have for people:
1. What does PBASIC do if you try to divide by 0. RoboEmu currently crashes.
2. Is it legal to have more than one SHIFTOUT (reinit master uP)? RoboEmu currently allows this, but I'm not sure if the actual controllers do.
3. What does PBASIC do with array-out-of-bounds type errors? Yes, this does mean I'm currently working on supporting arrays.
4. Are there any other operators/commands/features you'd like to see.
Unread 09-02-2003, 12:44
guzugi's Avatar
i noticed you mention that it "automatically reloads files"? how does one do that? for example: i use roboemu in parallel with the stamp editor. When i make a change on the program, i have to switch to roboemu, browse for the file again, and then run it again...is there a shortcut to just say "reload the current file"?
Unread 09-02-2003, 12:52
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
And can you change the switch names like dashboard v1.1?
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 09-02-2003, 13:03
guzugi's Avatar
Looks like you can, just double click on the titles, and change the name!
Unread 09-02-2003, 13:11
If you pauses the emulator (ctrl + p) and then start it again (ctrl +p), it will check to see if the file has been saved since the last load. If it has, it will ask you if you want to reload. Say "yes" and it should work correctly. Let me know if it doesn't.
Unread 09-02-2003, 13:16
guzugi's Avatar
ya, cool, that works!
Unread 09-02-2003, 13:21
2) According to Tom Watson at Innovation FIRST, you can reinitialize the master uP more then once. I have not tried it though.
I'd like to see a "real-time" mode, that runs through one loop and then pauses for the rest of 26 ms.
I'd also like to see a single step mode, so that it runs one loop of your program, and the pauses till you step again.
Unread 09-02-2003, 13:24
Thanks for the info. I'll give it a try on a real robot soon, but hopefully it will work.
How fast is RoboEmu running for you right now? The way it's written, it should run at a maximum of one loop every 26ms. Is this not happening?
Single-step would be very cool and very easy to implement. I'll see what I can do.
Unread 09-02-2003, 13:30
Bit Twiddler
FRC #2832
I tried the time again, and even reset my computer, and the time is about 2x fast. And, the serout must have all the numbers in, unlike the old one.
Unread 09-02-2003, 13:34
I agree with Steve. It is at least 2 times faster then it should be. It may be even more then that.
Unread 09-02-2003, 15:12
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
THAN. Have you been programming PBASIC too long?
Unread 09-02-2003, 16:05
guzugi's Avatar
I'm not sure if it this version, or if it's all, but it doesn't seem to support the "Toggle" command for feedback lights on the operator control.
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
Making RoboEmu 1.09 work rbayer Programming 2 14-01-2003 00:49
RoboEmu 1.08 released rbayer Programming 9 26-12-2002 22:31
RoboEmu 1.07 rbayer Programming 3 08-12-2002 18:28
RoboEmu for Linux (PBASIC emulator) rbayer Programming 5 21-11-2002 21:08
