Go to Post I don't mean to sound harsh, but I do not want you to get your hopes up. There are deadlines in FIRST. - RoboMom [more]
Unread 08-02-2003, 20:48
MikeDubreuil's Avatar
Carpe diem
FRC #0125 (Nu-Trons)
Programming Port I/O
Our team has been trying to tap into the programming port. However, every attempt has been marked with a Basic Run Error. We can't even get Serout to talk to Hyper Terminal.
Programs will run until you try to "call" from Hyperterminal. Then the RC will experience a Basic Run Error. Does anyone have any positive experience with serial communication over the program port?
Unread 08-02-2003, 21:07
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
You cannot use Hyperterminal as it sets the DTR line to high. This makes the Stamp think you are trying to program it and causes it to reset. For now, you're going to have to find a different program to view it with, or wait a few days and I'll see if I can throw together a quick serial port viewer.
--Rob
Unread 09-02-2003, 13:59
Carpe diem
I have used Hyperterminal before. Approximately 3 years ago with a Stamp BS2 and a development board. My Stamp book has information on connecting the Stamp to Hyperterminal. Unfortunately, that book is 100 miles away from me right now.
Unread 09-02-2003, 18:25
Ryan Meador Ryan Meador is offline
Team Role: Electrical
Ryan Meador will become famous soon enough
You could build your own serial cable with all the pins disconnected except for the 2 needed for tx/rx. You could also write your own computer program that would read from the port (like 40 lines of C++, almost all of which is setting port options)
-Ryan
"You're not a real programmer until you end all your sentences with semicolons;"
Unread 10-02-2003, 17:07
mjosephi mjosephi is offline
mjosephi is an unknown quantity at this point
When you launch hyperterminal set Flow Control to None and that should allow you to communicate with the BS.
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
Horror Story - Laptop com port again Lloyd Burns Programming 3 17-03-2003 07:33
Dashreader.dll: A Visual Basic .NET user control to read the dashboard port Ameya Programming 4 12-01-2003 23:40
Change to Initializing Inputs and Outputs Jferrante Programming 4 07-01-2003 11:36
Programming Port GreenDice Programming 12 10-01-2002 09:14
