Go to Post All we know is the "Oh my God, No data/Radio...reset...reset" dance before our matches! - tenfour [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
Unread 11-12-2013, 19:35
khanh111 khanh111 is offline
Outreach/Scouting/Software Manager
AKA: Hamzah Khan
FRC #1540 (The Flaming Chickens)
Team Role: Student
khanh111 has a spectacular aura aboutkhanh111 has a spectacular aura about
Internet at Competitions
My team has traditionally used a web application for our scouting application which has allowed our scouting head in the pits to access data from the stands.
However, we have enormous problems with internet access each year that we attempt to negate through use of various offline technologies.
We use 6 tablets, each with 4G internet access from AT&T in Portland (and Champs). However, at Portland, and especially Champs, the internet access will not work due to network congestion.
For other teams who use web apps, how do you access the internet?
Thanks!
Unread 11-12-2013, 19:53
Michael Hill's Avatar
Re: Internet at Competitions
We use a similar setup (4G tablets), but we've also got a 4G modem that has a bit better antenna if we really need it that we can wire into our tablets. Our scouting software has the ability to temporarily cache the data if it can't upload it to the database. It holds the data until a connection is established, then dumps it all at once.
Unread 11-12-2013, 20:05
yash101 yash101 is offline
AKA: null
I think that it would be wise to carry something like a 1W 4G antenna (if you can even get one). You'll be able to communicate with a tower possibly 80 to 100 miles away! Connect that into a switch and that can offer ethernet connectivity. That's where Windows tablets come in use! They have ethernet ports!
Otherwise, since you are running a webpage-based scouting app, just run the server at the competition! That is the reason why the scouting app I'm working on will be a fail. Even though I am heavily using WebCache to store the page, an internet connection will be required. Since you live in the West coast, like me, you might want to use Verizon or Sprint or ATnT. WiMax will give a 40 mile range! Even better, have a WiFi pack running a 16 Watt antenna (you'd have to build this yourself!) with you, and one copying your hotel's wifi! You'll get WiFi from anywhere in the city!
Unread 11-12-2013, 20:38
arbym arbym is offline
AKA: Rob Miller
arbym is on a distinguished road
We actually queue the transactions which is different than caching the web page. We estimated last year that we could run several hours without a 4g signal. At worse case we could walk out to a hallway or even outside to flush the queue.
Rob Miller
Scouting Mentor
Innovators Robotics
Unread 11-12-2013, 20:46
AKA: null
I think that it is time that FRC makes available a limited-use wireless network, only available to certain people! That would make internet access possible without causing too many robot network communication troubles!
Otherwise, why doesn't FRC special-order the radios to work on a special frequency? Maybe even a channel not used very often.
I have two routers at home, sitting next to each other. They used to fight over the signals, causing them to get very hot and keep on crashing. I changed the channel of one of the routers and now I get no problems!
Unread 11-12-2013, 21:19
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
And everything old is new again: http://team358.org/files/electrical/...Manual2007.pdf
FIRST moved away from custom radios to make it easier to utilize COTS parts/systems during competitions. Things might swing the other way soon enough.
Unread 11-12-2013, 21:21
DonRotolo's Avatar
Back to humble
FRC #0832
Why in the world would you need Internet access for scouting? What is it you need from outside the venue?
Unread 11-12-2013, 21:27
AKA: null
I mean a small difference, just in the antenna, like 2.6GHz instead of 2.4!
I want to design a scouting application that will allow every team to view the same results and use the same tools. The server will be at home to make sure everyone around the world can connect to it!
Unread 11-12-2013, 22:02
Brandon Ha Brandon Ha is offline
FRC #0302 (Dragons)
Team Role: Electrical
Brandon Ha is on a distinguished road
I am speaking from FiM's side, which is WiFi is bad. Do NOT use it at competitions. Many things can and will go wrong, not for the users but the field people. They will get angry at you.
We all make mistakes.
I make one everyday.
The important thing is.
( \_/ )
(^_^)
Unread 11-12-2013, 22:35
AKA: null
First of all, do you mean FMS (Field Management System)? Also, you say, don't use WiFi in the competitions, but you don't really explain why. Also, yes, they will get angry at you, but it isn't a bad thing, like how you are making it sound. That is to just keep the fields working properly. WiFi is a thing that is quite useful in competitions because it will network devices together, allowing them to communicate. That is the reason why you use Bluetooth in competitions!
Bluetooth should be good as long as you aren't torenting a 16GB file (you'll get angry by the 3MBps max speed)!
Unread 11-12-2013, 22:37
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
FiM = FIRST in Michigan. Though I'm not sure which one he meant, now that you bring it up, but I'm fairly certain he meant FiM being from a Michigan team.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 11-12-2013, 22:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
At the Long Beach regional we've used Clear WiMax USB modems, with Cradlepoint routers and a wired network. Of course, this only works within a couple miles of a Clear (sprint) WiMax tower, and the bandwidth is not great.
Unread 11-12-2013, 23:08
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Last year, to access our SVN server during competition, I shared my internet connection from my phone to my computer while in the pits.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 11-12-2013, 23:11
AKA: null
the max data rate is 14Mbps, 3 times as fast as my home's internet. The funny thing is that I live within the urban areas of PHX. My community is a tad newer so we have all the good technology.
Unread 12-12-2013, 00:05
mechanical_robot's Avatar
mechanical_robot mechanical_robot is offline
Team Role: Driver
mechanical_robot will become famous soon enough
Well it's a good way to scout with the possibilities of it.
Also it allows teams to make something cool with their app or web app using the internet.
[IMG] code is Off
