Go to Post A solution will present itself, all you have to do is be ready to take advantage of it when it does. - James1902 [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #91   Spotlight this post!
Unread 11-12-2013, 22:32
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Back for more..VEXpro 2014 Product Unveiling
Originally Posted by sanddrag View Post
I don't understand this one bit, but I'd like to. Is there a more in depth or perhaps visual explanation?
I spent a good amount of time researching this at one point, and as far as I could tell, to make a gear with less toothcount have the same pitch diameter as a larger gear, you take the gear with the toothcount you want and let the teeth extent all the way out until their involute profiles meet, instead of cutting them off at a given diameter (as you would to make it have it be the normal diameter).
Of course, I may be totally wrong, so someone else feel free to correct me on this.
-Plutarch
  #92   Spotlight this post!
Unread 11-12-2013, 22:34
Clinton Bolinger's Avatar
Clinton Bolinger Clinton Bolinger is offline
FF - PureMichigan
FRC #2337 (EngiNERDs)
Clinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond reputeClinton Bolinger has a reputation beyond repute
If teams would like to compare shipping options between VEX (Greenville, TX) and The Robot Space (Lapeer, MI) feel free to check out http://ship.therobotspace.com
The Robot Space provides teams in the Midwest and on the East Coast with Next Day or Second Day shipping at Ground Rates on all VEXpro, VEX and VEX IQ product lines.
Also, be sure to check out all of the products at www.therobotspace.com (we will be working each day to add pictures and more information).
Thanks,
Clinton Bolinger
clinton[at]therobotspace.com
  #93   Spotlight this post!
Unread 11-12-2013, 22:35
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
This is the best google image result I could find given the term "addendum modification". Pretty neat concept.
  #94   Spotlight this post!
Unread 11-12-2013, 22:40
Andrew Lawrence
Posts: n/a
Originally Posted by Oblarg View Post
Are you sure? The plastic AndyMark ones held up marvelously this past year.
And look how big those are.
  #95   Spotlight this post!
Unread 11-12-2013, 22:44
AKA: Scooby
I've seen quite a few plastic pulleys in drivetrains (I believe 207 are one example of this-they 3d printed wheels at least, not sure about pulleys). And even so, the only usage of pulleys isn't drivetrains...
  #96   Spotlight this post!
Unread 11-12-2013, 22:45
Oblarg Oblarg is offline
AKA: Eli Barnett
Sure, but seeing as I didn't see anything even resembling wear on them, I'm not convinced you couldn't get quite a bit smaller with the same material and have it still work.
"The breakfast of champions!"
  #97   Spotlight this post!
Unread 11-12-2013, 22:49
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
My understanding of this is that you are going to shrink your tooth addendum, which in turn will allow you to shrink your tooth width. This allows you to maintain the same circular pitch. By still having the same tooth to tooth spacing.
The depth of mesh is the only measure that will change in this case, also know as the gears clearance.
  #98   Spotlight this post!
Unread 11-12-2013, 22:50
ttldomination's Avatar
Sunny
Some of CADs are missing or broken, but otherwise, looks decent. We'll need to seriously assess some of these things and how they would fit into our structure.
Personally, the extended gearboxes are great, but the tubing and gussets don't necessarily work for our team. But then again, they're not really marketed for "us."
- Sunny G.
1648: 2013-2014
5283: 2015
  #99   Spotlight this post!
Unread 11-12-2013, 22:57
MrRiedemanJACC MrRiedemanJACC is offline
FRC #2611 (Jacktown Vectors)
MrRiedemanJACC will become famous soon enough
Clinton,
Awesome job on The Robot Space. Looks like a great thing for the teams here in Michigan and across the midwest.
Here's the information on shipping when I put it into your calculator to Jackson, Michigan:
Ground: $6.90 vs $8.51
2nd Day $6.90 vs $30.22
Next Day $6.90 vs $81.66
Talk about a no brainer! Hope you have a big warehouse!
I will be sending you a PM on how to get you into our Purchase Ordering system, get you our tax exempt information, etc, etc, etc.... Because we will be buying parts!
John Riedeman
  #100   Spotlight this post!
Unread 11-12-2013, 23:57
President, VEX Robotics, Inc.
Profile Shift, or addendum modification, can be positive or negative. For a positive profile shift, the tooth looks longer and pointier. For a negative profile shift, the tooth looks short and stubby.
The primary use for profile shift in industry is to avoid undercut in small gears. If you want to see severe undercut then look at the 12 tooth CIM pinion. Undercut lowers the gear's max load carrying ability and is necessary so the mating gear's tooth tip does not interfere with the root of the smaller gear.
As a rule, every gear we design will have profile shift to avoid undercut except when the market conditions do not allow it. For example, the 14.5 pressure angle, 20 Diametral Pitch gears that have been used as a standard in FRC have always used 0 profile shift. Making a 12T pinion with 0 profile shift now would mean all of the center distances would be too close together.
This is very important for really small gears with small module (1 or .5). All of our VEX motors used in VRC have significant profile shift to increase the load carrying capability.
All of the Versaplanetary gears have addendum modification to minimize the
planetary backlash and increase the strength as much as possible.
You really are shifting the profile either out (+) or in (-). QTC gears has really great introductory information on their web site about gears. I make all my new engineers read that web site before I give them the more advanced information.
By the way, the 11T pinion is actually stronger in every way than the 12T gear due to the 12T gear's severe undercut. However, the 12T gear's strength is plenty sufficient for use with a CIM motor.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #101   Spotlight this post!
Unread 12-12-2013, 00:13
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Paul
...and it's soooo awesome.
  #102   Spotlight this post!
Unread 12-12-2013, 00:20
BBray_T1296's Avatar
I am Dave! Yognaut
AKA: Brian Bray
Originally Posted by geomapguy View Post
Are the versa planetary base models 1:1 ratios??
Yes, as they have no actual gears. The ring and planet gears only come with the ratio add-ons.
This is a great tool thanks. I am pretty sure we will never need to ship from Michigan, we will stick to driving 20 miles down I-30 and picking them up from VEX ourselves
  #103   Spotlight this post!
Unread 12-12-2013, 00:30
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
This makes sense, but I don't think our applications are limited by the strength of these undercut gears. The ability to use different tooth counts with the same center-center distance looks like a huge advantage though, especially in the tooth range for pinions. (fun fact: you derailed a recent project of mine with this revelation)
All of the Versaplanetary gears have addendum modification to minimize the planetary backlash and increase the strength as much as possible.
Just making sure: is this something on the new models only? Any compatibility issues with combining stages from last year with stages from this year?
BTW, I appreciate the openness to questions and details from the vexpro guys; it gives me a strong urge to buy your stuff. Good business model.
  #104   Spotlight this post!
Unread 12-12-2013, 00:33
JB's Avatar
JB JB is offline
FRC Kit of Parts Engineer
AKA: Jon Bryant
FRC #0238
JB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of lightJB is a glorious beacon of light
Will the standard 2 cim ball shifter be given the optional lower and 3rd stages seen on the 3 cim version? Also has the bearing blocks / chain tensioning device for the versa frame been placed on the website? I have not be able to locate them.
My posts are solely my own and do not necessarily reflect the views or opinions of FIRSTŪ or my affiliated team.[/center]
FRCŪ Kit of Parts Engineer: 2014-Present
Team 238: 2016-Present
Team 1403: 2008-2014
  #105   Spotlight this post!
Unread 12-12-2013, 00:43
AlecS AlecS is offline
FRC #1323 (Madtown Robotics)
AlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond repute
Yes the Versa-Block and CAM can be found under /VEXpro/WCP/versachassis, here
Alec S.
Engineer - Sales Representative, WestCoast Products || Twitter
MadTown Robotics Team 1323
