Go to Post Wait, we have to be logical? - JaneYoung [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #121   Spotlight this post!
Unread 12-12-2013, 01:42
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Re: Back for more..VEXpro 2014 Product Unveiling
Originally Posted by Paul Copioli View Post
The plates for the WCP PTO transmission are the same plates as the WCP 3 CIM shifters. When you purchase a WCP 3 CIM Shifter, you get the plates necessary to do a PTO. Please note that only the WCD version of the 3 CIM shifter supports the PTO option.
So there would be no PTO on the 2 cim shifter. That clears up a lot.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
  #122   Spotlight this post!
Unread 12-12-2013, 02:36
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally Posted by s_forbes View Post
11 tooth pinion with the same pitch circle diameter as a 12 tooth pinion? Sounds like dark magic to me.
We discovered these three years ago and have been referring to them as the "tricky trickster" pinions ever since. They are fantastic for having multiple options for top speeds in a drive gearbox without having to modify anything.
2001-2004: Team 100
2006-Present: Team 254
  #123   Spotlight this post!
Unread 12-12-2013, 02:44
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Will the versaDog be available on its own?
2016: FRC 865 Mentor
  #124   Spotlight this post!
Unread 12-12-2013, 02:47
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
A COTS 3 pound PTO gearbox. FRC certainly has come a long way.It used to be only the top 1% of teams could pull something like that off.
  #125   Spotlight this post!
Unread 12-12-2013, 08:43
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Does anyone know how they plan on mounting the transmissions to the versa chassis? Is it something they will have a mounting plate for or will we be responsible for however we want to mount them?
  #126   Spotlight this post!
Unread 12-12-2013, 10:19
Sparky3D's Avatar
Sparky3D Sparky3D is offline
AKA: Dustin D
FRC #1736 (Robot Casserole)
Sparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of lightSparky3D is a glorious beacon of light
I'm hoping that Vex/WCP will elaborate on this as well. After looking at the pictures and release video, it looks like they drilled holes in the sides of the frame rails and face mounted them, but I'm hoping there's more to it than that. Trying to get the mounting holes properly aligned with just "a saw and a drill" would be rather difficult.
  #127   Spotlight this post!
Unread 12-12-2013, 10:41
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
That is where I was getting at. They said a drill and wrench so we might have to wait till the manual is published to see what they have planned. For a lot of teams that would be rather difficult but the good part is that hopefully as long as you can get it fairly square and the flush mount on the face of the shifters to the 1x2 face then the versa blocks will automatically put your sprockets in line and allow you to still have a decent drive line. That is if they designed them to be offset the same...I assume they did
  #128   Spotlight this post!
Unread 12-12-2013, 10:57
On a typical WCD, you use the bearing block to bolt and clamp the gearbox to the drive rail. Most teams also utilize the bottom standoffs to bolt though one face of the tubing and the gearbox. Not sure if those bolt hole dimensions have been standardized or not.
If those holes aren't provided, you could essentially mount the front plate of the gearbox to the tubing using the versablock, and then just drill through the standoff holes in the faceplate. Wouldn't be too difficult as long as the versablock keeps the plate aligned.
  #129   Spotlight this post!
Unread 12-12-2013, 11:02
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
It appears that they attach to the VersaBlock which is clamped securely over the tubing. The only hole you would have to drill is the clearance hole for the hex shaft. You could use a step drill to bore an oversized hole to allow for chain/belt tensioning on the end blocks.
2015 Newton Semi-Finalist (3130, 2468, 3310, 537)
2015 Lubbock Regional Winner (2468, 3310, 4799)
2014 Galileo Quarter-Finalist (2052, 70, 3310, 3360)
2014 Colorado Regional Winner (1138, 3310, 2543)
2013 Texas Robot Roundup Winner (3310, 624, 2848)
2013 Archimedes Semi-Finalist (126, 3310, 1756)
2013 Dallas Regional Winner (148, 3310, 4610)
2012 Dallas West Regional Winner (935, 3310, 4206)
  #130   Spotlight this post!
Unread 12-12-2013, 11:11
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
They are planning to put the entire shifter on the versa block...? That doesn't seem like the best idea, not saying they are not strong enough but doesn't seem like a rock solid idea to me. Please share ideas on this.
  #131   Spotlight this post!
Unread 12-12-2013, 11:15
AdamHeard's Avatar
Lead Mentor
That would be plenty strong if bolted up right.
Adding two outer bolts by match drilling would beef it up, but that versablock clamping the frame is a serious joint.
  #132   Spotlight this post!
Unread 12-12-2013, 11:18
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Could you guys provide some of the information pertaining to HTD versus GT2 specifically in ratcheting performance? I tried finding data to back up the claim of HTD being better for rapid direction changes and can't find anything to substantiate this.
Mentor 2415
  #133   Spotlight this post!
Unread 12-12-2013, 11:23
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
Thank you everyone at Vex Robotics/IFI for introducing all of these new products, it is evident that you really listened to everyone's feedback and have produced a great suite of products to meet everyone's needs. 225 is already working on our pre-kickoff purchase list.
TechFire 225 -- Website -- Facebook
2015 & 2016 MAR Champions
Past teams: 234, 1747
  #134   Spotlight this post!
Unread 12-12-2013, 11:29
Alpha Beta's Avatar
Alpha Beta Alpha Beta is offline
Strategy, Scouting, and LabVIEW
AKA: Mr. Aaron Bailey
FRC #1986 (Team Titanium)
Alpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond reputeAlpha Beta has a reputation beyond repute
We do not know the rules for 2014, so I'll ask this question in reference to last year. Would the PTO gear box from WCP have been legal in 2013? The gear box without pneumatic cylinders is around $350. With both cylinders it's $430-ish. You can purchase the gear box without them, but it won't function. Of course the same is true for motors and pinions. If you purchased the full assembly with pneumatics, motors and pinions for just over $525 would it have been legal?
4.1.3.2 R12
No individual item shall have a value that exceeds $400 USD. The total cost of COMPONENTS purchased in bulk may
exceed $400 as long as the cost of an individual COMPONENT does not exceed $400.
4.1.3.5 R15
If a COTS item is part of a modular system that can be assembled in several possible configurations, then each
individual module must fit within the price constraints defined in R12.
If the modules are designed to assemble into a single configuration, and the assembly is functional in only that
configuration, then the total cost of the complete assembly including all modules must fit within the price constraints
defined in R12.
In summary, if a VENDOR sells a system or a kit, a team must use the entire system/kit
Fair Market Value and not the value of its COMPONENT pieces.
Example1: VENDOR A sells a gearbox that can be used with a number of different gear sets, and can mate with two different motors they sell. A team purchases the gearbox, a
gear set, and a motor (which are not offered together as an assembly or kit), then
assembles them together. Each part is treated separately for the purpose of BOM
costing, since the purchased pieces can each be used in various configurations.
Example2: VENDOR B sells a robotic arm assembly that the team wants to use.
However, it costs $700, so they cannot use it. The Vendor sells the “hand”, “wrist” and
“arm” as separate assemblies, for $200 each. A team wishes to purchase the three
components separately, then reassemble them. This would not be legal, as they are
really buying and using the entire assembly, which has a Fair Market Value of $700
PS. If FIRST had a goal of more teams doing their own design work they could lower the $400 limit. If they wanted to lessen the amount of design work they could raise it instead.
Regional Wins: 2016(KC), 2015(St. Louis, Queen City), 2014(Central Illinois, KC), 2013(Hub City, KC, Oklahoma City), 2012(KC, St. Louis), 2011(Colorado), 2010(North Star)
Regional Chairman's Award: 2014(Central Illinois), 2009(10,000 Lakes)
Engineering Inspiration: 2016(Smoky Mountain), 2012(Kansas City), 2011(Denver)
Dean's List Finalist 2016(Jacob S), 2014(Cameron L), 2013(Jay U), 2012(Laura S), 2011(Dominic A), 2010(Collin R)
Woodie Flowers Finalist 2013 (Aaron Bailey)
Championships: Sub-Division Champion (2016), Finalist (2013, 2010), Semifinalist (2014), Quaterfinalist (2015, 2012, 2011)
Other Official Awards: Gracious Professionalism (2013) Entrepreneurship (2013), Quality (2015, 2015, 2013), Engineering Excellence (Champs 2013, 2012), Website (2011), Industrial Design (Archimedes/Tesla 2016, 2016, 2015, Newton 2014, 2013, 2011), Innovation in Control (2014, Champs 2010, 2010, 2008, 2008), Imagery (2009), Regional Finalist (2016, 2015, 2008)
  #135   Spotlight this post!
Unread 12-12-2013, 11:41
Racer26 Racer26 is offline
I agree it starts to get into a grey area on the legality. IMO, I would argue that the cylinders are a separate entity. You can use them on their own for other purposes. Presumably there is some way you could lock the transmission into one gear only, so I don't think the cylinders should count as part of the transmission's BOM cost.
