Go to Post Although it took me a little while to find my niche in the program, every moment spent has been one great memory after another. - Amanda Morrison [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #151   Spotlight this post!
Unread 12-12-2013, 14:21
AdamHeard's Avatar
Lead Mentor
Re: Back for more..VEXpro 2014 Product Unveiling
I would wager they are actually making the claim that HTD is stronger than the traditional trapezoidal tooth, and not gt2. This is just conjecture though.
EDIT: I'm wrong, rewatched video. He was referring to gt2.
  #152   Spotlight this post!
Unread 12-12-2013, 14:32
Andrew Lawrence
Posts: n/a
Originally Posted by Chris is me View Post
Could you post more information about your setup? Tooth count of both systems, pulley material, use of tensioners vs exact center, etc. We've had almost the exact opposite experience, but our experience is probably possibly user error rather than an accurate comparison.
We ran a 6wd WCD in the fall to test new ideas for the 2014 season, especially play around with belts. All pulleys had 24 teeth and were made of aluminum pulley stock. We had a tensioning system in place, but rarely had to tension after putting the belts on. It should be made to note that during these tests we added weight to our robot to reach 120 lbs so we could determine a factor of safety for each type of belt. During these weighted tests, we ran full forward, full backward, into walls, and rapid spin turns and reversing spin directions to test the belt reaction. While under lower weight and low risk driving both belts performed equally, however upon testing the heavier robot and heavier driving we found the GT2 belt start to ratchet, while the HTD belt stayed in place.
  #153   Spotlight this post!
Unread 12-12-2013, 14:47
Chris is me's Avatar
AKA: Pinecone
Did you adjust tension between belt changes?
What width were the belts?
Did you use different pulleys or the same type? Which kind?
  #154   Spotlight this post!
Unread 12-12-2013, 14:55
Andrew Lawrence
Posts: n/a
The tension was the same on both HTD and GT2, and to compensate for any discrepancies we tried both belts multiple times, switching out between rounds.
The belts were 9mm wide, 5mm pitch.
All pulleys were the same aluminum 24 tooth cut from the same stock, all the same width.
  #155   Spotlight this post!
Unread 12-12-2013, 15:00
AKA: Pinecone
GT2 pulley stock is different than HTD pulley stock, which is different than regular timing belt stock. I don't think it's fair to compare belt performance when at least one of the belts is running on a pulley it wasn't designed to run on.
  #156   Spotlight this post!
Unread 12-12-2013, 15:02
AdamHeard's Avatar
Lead Mentor
These two links help compare that a little bit;
http://www.gates.com/brochure.cfm?br...cation_id=3881
  #157   Spotlight this post!
Unread 12-12-2013, 15:04
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is online now
AKA: Sean
FRC #2415 (Wired Cats)
I'm going to guess the pulley stock was HTD?
Mentor 2415
  #158   Spotlight this post!
Unread 12-12-2013, 15:14
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
Originally Posted by JVN View Post
Hi Sean,
Unfortunately, I don't have a data sheet to back this up. We spoke directly with a few belt manufacturers, off the record on this topic.
Of course those users who would prefer GT2 belts can purchase them from any number of suppliers. VEXpro has chosen HTD based on the feedback we received, and some simple preliminary testing.
If you have any concerns, feel free to email prosupport@vex.com to discuss further.
-John
I've done some searching on this claim and it seems difficult to directly find information to back it up, but using the information here, http://www.transdev.co.uk/catalogues...pretension.pdf
And making the assuming that a lower required belt preload for the same transmitted power would mean that the belt would be less likely to ratchet.
This is a pretty safe assumption because the preload is the belt tension needed to maintain contact given a transmitted power so lower preload better the teeth are at self maintaining contact.
FP =[( P*k*10^5)/(n*d0)]+f0*b*(It/Lb)
Now assuiming that all factors are the same except k and f0, these are the properties derived from the belt tooth structure.
Looking on the website and at the offered belt profiles they do not offer exactly GT2 and HTD belts so i picked similar profiles, XL for GT2 and 5M for HTD.
Profiles can be seen here, http://www.transdev.co.uk/pages/belt...prene_main.htm
P=10Kw
n=1000rpm
d0=10mm
b=5mm
It=29.4mm
Lb=1
[GT2~XL] Fp=1051.45
[HTD~5M] Fp=429.4
This would support the claim that a HTD profile would be much less likely to ratchet as it requires a lower preload to maintain tooth contact at a given transmitted load.
  #159   Spotlight this post!
Unread 12-12-2013, 15:36
apples000's Avatar
apples000 apples000 is offline
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
A few of the cad models are messed up. The color of the models was a nice addition, but the wrong parts are used sometimes, especially in the shafts for the gearboxes. Often times they are too long and go through a motor. See the 3 CIM PTO box.
I'm also confused by the wcp 3 cim pto design. It's much thicker than it needs to be. To begin with, the distance the shifting dog travels is about twice what it needs to be. A quick reconfigure of the design let me slim the gearbox down by 1.25". There's a ton of wasted space. Also, the outer plate needs to hold 3 bearings, 4 standoff mounts, and 4 cylinder mounts, yet it has spots for mounting the CIMS. Again, this could be make significantly smaller.
I'll post a picture of what i'm talking about in an hour or so.
  #160   Spotlight this post!
Unread 12-12-2013, 15:42
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
If I'm not mistaken, the distance between the gear and the PTO is probably to allow versatility in adding Versahubs/Versapulleys; ie, you're not restricted to using pulleys of a certain thickness/can use multiple pulleys/sprockets.
  #161   Spotlight this post!
Unread 12-12-2013, 15:44
Are you talking about the space that holds sprockets for chain or belts, or something else? Plus, what Steven said.
Parallel symmetrical plates allow for quicker and more efficient fabrication, I would imagine.
  #162   Spotlight this post!
Unread 12-12-2013, 15:52
apples000's Avatar
Here's what I'm talking about. I got the gearbox slimmer by 1" (3.5" to 2.5"), and switched the standoffs to screws in the CIM mounting holes. My design doesn't have bearings, but you get the idea.
ID:	15543  Click image for larger version
  #163   Spotlight this post!
Unread 12-12-2013, 15:53
lol
I think you ought to read the product description again. That configuration is intended for a typical WCD setup. That is why there is a space for your sprockets.
  #164   Spotlight this post!
Aren_Hill's Avatar
Build Nifty Things
The PTO Kit reuses many existing parts, including the main output shaft, this would typically be cut off where it meets the opposite plate. Rather than creating slightly tweaked versions of a bunch of existing parts we chose to repurpose existing things.
Also space is required for the gear/sprocket/pulley attached to the Versadog, Hence why this kit is listed as an option to only work with the WCD version of the 3 CIM DS.
A guy who likes robots.
  #165   Spotlight this post!
Unread 12-12-2013, 15:56
apples000's Avatar
Yup, my bad. I see what you mean about space for the plate sprockets. That being said, if you used a little sprocket that had the dog pattern in it, you could probably get away with this.
