Go to Post You won't find anything in school that says you have to share ideas or strategy with your football rivals. - Al Skierkiewicz [more]
Unread 12-12-2013, 13:01
yash101 yash101 is offline
AKA: null
MicroControllers at competitions
I know it is a tad early for me to post about this, but I think that when I go to competition, I should take a Propeller Chip, MCP3204, a 120Amp shunt resistor, and some other various things. The reason why is because last year, we experienced the problem that our shooter motors kept dying and we had no way to measure the motor's current draw (because we didn't want to damage our fluke by a current spike). What do you guys think of this idea to aid in competition debugging?
Unread 12-12-2013, 13:30
Re: MicroControllers at competitions
Dev,
You are asking for a 0.1 ohm/1500 watt resistor. Do you have those laying around?
http://store.mwands.com/diversion-du...12-24-48-volt/
Unread 12-12-2013, 13:32
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Out of curiosity, what motors were you using?
Are you thinking for in-match debugging, or in the pits? Be aware that in-line current monitoring has been illegalrestricted by past years' rules.
Seems like this would be a good thing to have tested enough in your shop to know that the motors wouldn't die. That way you have time if you need to adjust gear ratios, etc.
Speaking of Fluke, what about an AC/DC clamp-on current meter?
FRC 766, 2015-, Mentor
Unread 12-12-2013, 13:38
RyanCahoon's Avatar
Dev,
Al,
What's the difference between the device you linked and this one: http://www.amazon.com/Amico-current-.../dp/B008SOXFZC ?
Unread 12-12-2013, 16:07
Originally Posted by RyanCahoon View Post
Be aware that in-line current monitoring has been illegal by past years' rules
Depends on how you do it I would think. What rule did you have in mind?
Unread 12-12-2013, 16:14
Yours is 200 amps at 0.075 volts (shunt)
Al's is 125 amps at 12 volts (load resistor)
Unread 12-12-2013, 16:20
His post was admittedly somewhat ambiguous, but that's not the way I interpreted it.
I think he wants to insert the shunt in series in one of the motor leads and measure the voltage drop across it to get current.
Aside from questions of FRC legality, the shunt Ryan linked would would work: it would dissipate roughly 7 watts at 133amps:
0.075V/200A = 375e-6 Ohms. 133amps * 375e-6 ohms = ~7watts.
As you have previously pointed out on many occasions Al, instead of a shunt the voltage drop across a length of existing wiring would suffice to get a rough measure of current (for large currents).
Unread 12-12-2013, 16:33
magnets's Avatar
magnets magnets is offline
Your multimeter (should) have a fuse to protect itself from current, so you should be all set.
What does the current draw tell you? Our team has attended 42 robotics competitions, countless offseason, and have played close to 1000 matches. We have never needed to measure the current draw of a motor at competition, nor have we heard of anybody needing to.
Unread 12-12-2013, 16:35
Joining the 900 Meme Team
FRC #0079
I've used the current monitoring in Jags to diagnose binding in the drivetrain (old robot had picked up some gunk and locked up one side of the drive) as well as to identify that we were initially over geared this year. It's useful data to have for debugging.
Unread 12-12-2013, 16:37
magnets's Avatar
Was there anything you couldn't measure with a multimeter? A clamp on ammeter costs $60. The shunt resistor costs over $100.
Unread 12-12-2013, 16:43
FRC #0079
Dunno, didn't need to. We had Jags on a CAN bus so it was baked in for us. But my gut feeling is no, a clamp on ammeter woulda been fine.
Unread 12-12-2013, 16:47
$100 ?? The shunt resistor Ryan linked costs $7.52
Or don't even use a shunt. Just measure the voltage drop across a length of existing wiring.
Unread 12-12-2013, 16:50
Are you reluctant to post some details of your shooter design? If you would do that, there are people here who could walk you through the math and show you what you were doing wrong.
Unread 12-12-2013, 16:53
FrankJ's Avatar
FrankJ FrankJ is online now
Robot Mentor
FRC #2974 (WALT)
Beware that most current clamps measure AC only. The DC capable ones tend to be expensive.
Unread 12-12-2013, 16:54
magnets's Avatar
Here's a 400 amp dc one for $50.
http://www.sears.com/craftsman-digit...p-03482369000P
