Go to Post I never had any doubt; good people who do good quality work will always prosper. - Gary Dillard [more]
Unread 13-12-2013, 01:33
Andrew Lawrence
Posts: n/a
VersaChassis Attempt 1
Here's my first attempt to use all COTS items and parts from the new product line to make a drivetrain. It could be simplified a lot, and the big complexity is the bumper mounts which I was lazy with. Other than that, it's relatively simple. I put in the correct weights for each object and Solidworks is telling me 37 lbs with everything pictured (20 lbs of which are the transmissions + CIMs).
Unread 13-12-2013, 01:47
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
Re: VersaChassis Attempt 1
Mmm, Beef.
Actually it's probably not that heavy since it is mostly .04, still I would try to do away with the front and back sections. see if you can hook them up to the front and back 1x2 rail. If the colsons get in the way you can add a spacer of some kind to get the height. Nice use of the corner gussets.
Unread 13-12-2013, 09:11
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
How do these fasten together? Rivets, nuts and bolts, or some option that I'm not thinking of?
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 13-12-2013, 09:30
Andrew Lawrence
Posts: n/a
Rivets, just didn't add them into the CAD.
Unread 13-12-2013, 09:36
FRC #1836 (MilkenKnights)
Double frames are unnecessary on a WCD. If you are willing to slightly modify the T gussets, you can rivet them on to the side rails and then cut off whatever would go into the bumpers.
Unread 13-12-2013, 10:16
Andrew Lawrence
Posts: n/a
Yeah, but I didn't want to modify any of the pieces in this design (to keep with the theme of not needing tools or resources to build it).
Unread 13-12-2013, 12:00
You need a saw just to cut the tube
