Go to Post 256:1 gear reductions provide surprisingly little torque once the gears have failed. - Kevin Sevcik [more]
Unread 13-12-2013, 12:30
jee7s jee7s is offline
Texan FIRSTer, ex-frc2789, ex-frc41
AKA: Jeffrey Erickson
FRC #6357
jee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond reputejee7s has a reputation beyond repute
Re: Learning Electronics
Originally Posted by yash101 View Post
Yes. I am familiar with Kirchoff's law! E{abs[ups]-abs[downs]}=0, where E means Sum of!
The Kirchhoff's Laws the previous poster is referering to are the circuit laws. They basically say that all of the voltages in a loop must equal zero, and all of the currents at a node must equal zero.
That leads to the mesh-current and node-voltage methods of circuit analysis, which are fundamentals to all circuit design. Highly recommended starting point!
2013 Alamo Regional Woodie Flowers Finalist Award Winner
2012 Texas Robot Roundup Volunteer of the Year
Texas Robot Roundup Planning Committee, 2012-present
FRC 6357 Mentor, 2016-
FRC 2789 Mentor, 2009-2016 -- 2 Golds, 2 Silvers, 8 Regional Elimination Appearances
FRC 41 Mentor 2007-2009
FLL Mentor 2006
FRC 619 Mentor 2002
FRC 41 Student 1998-2000
Unread 13-12-2013, 12:58
The ARRL Handbook is really good and should be availible at your library. It had enough theory to get you started, and then lots of projects.
Unread 14-12-2013, 21:54
yash101 yash101 is offline
AKA: null
What do you guys think of this? It's probably the most thorough book I've looked at!
Unread 14-12-2013, 22:01
DonRotolo's Avatar
Back to humble
FRC #0832
"Your session has timed out". Dead link.
Unread 15-12-2013, 00:50
foote stepped in
AKA: E. Foote
FRC #0868
The three textbooks I used for my sophomore level courses at Purdue were Linear Circuit Analysis 2nd Ed (DeCarlo/Lin), Microelectronic Circuit Design 4th Ed (Jaeger/Blalock), Digital Design 4th Ed (Wakerly) (for ECE201, ECE202, ECE255, ECE270).
I wasn't too thrilled with DeCarlo's book, but the subject matter (linear circuit analysis) is very important for a solid foundation in electrical engineering. Jaeger's book is very thorough, and very heavy. It'll have most things you'll want to know about diodes, transistors, CMOS logic, and amplifiers. I really didn't touch Wakerly's book, but that's because the notes and labs for the class were that good ( https://engineering.purdue.edu/ece270/ ). Note that the course website is reused for each semester, so in January the content may be reset.
Hope this helps.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 15-12-2013, 22:29
AKA: null
Sorry about that! That was the first time I used the library catalog system since they changed it up last! Here's a link to it on Amazon!
Unread 16-12-2013, 01:25
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
That made the engineer in me tingle
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 16-12-2013, 08:46
Dev,
As Joe pointed out the ARRL Handbook, even an old copy is a good book to put on your shelf. There should be several at your library. I would check out the ARRL website for other titles, all of them are pretty good. Check for a hamfest in your area. Should be one coming up soon as most areas have a midwinter fest in larger urban areas. You can pick up components for next to nothing. Bring a pack so you carry stuff home. you should be able to find little kits and lot's of books if you just look around. ARRL retailers usually carry their book inventory to the fest.
Check out http://www.arrl.org/shop/Technical/
If you hurry, I think they are still shipping for Christmas. As Don pointed out, digital electronics are a world away from analog circuitry. RF is much different than audio, etc. Start off with basic AC and DC circuits. Learn DC first so that you can see how components function and then move to AC from there. When I went through school, DC was an entire semester and a per-requisite for everything else.
Unread 16-12-2013, 11:43
EricWilliams EricWilliams is offline
FRC #2039 (Rockford Robotics)
EricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of lightEricWilliams is a glorious beacon of light
Originally Posted by nuttle View Post
I'll put in another plug for reading -- good books, websites, etc.[/url]?
One of the standards of the industry (getting a little long in the tooth, but the basics are things that don't really change): http://www.amazon.com/The-Art-Electr.../dp/0521370957
Unread 16-12-2013, 13:14
Michael Hill's Avatar
I'm going to be taking an online course from a friend teaching this:
http://contextualelectronics.com
It's kinda pricy, but I think it will be well worth it.
