Go to Post (middle school age) One time I had a truly awful day at school and came home crying. My mother's response? "Do you want to go to the build session tonight? It will make you feel better.." And it did. It always does. - rachelholladay [more]
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
  #181   Spotlight this post!
Unread 12-12-2013, 23:15
s_forbes's Avatar
s_forbes s_forbes is offline
anonymous internet person
FRC #0842 (Falcon Robotics)
Re: Back for more..VEXpro 2014 Product Unveiling
Some clarification if possible:
The difference between gears with versakey option and those without - does this refer to just the female versakey pattern in each gear? Do the non-versakey gears still come with the bolt pattern?
Also, I see two availability options: "In stock" and "Ships before kickoff". How long would it take each of these to ship if I ordered today?
  #182   Spotlight this post!
Unread 13-12-2013, 00:12
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
Do we have an ETA on documentation for the 3-CIM gearbox? I'm trying to figue our how to mount one to a piece of channel and as far as I can tell the logical thing (using the hexagonal home pattern) won't work with any standard screw cap size. Anyone know how this is supposed to work?
Note: I know I'm going to feel stupid after somebody points out that some specific holes are for mounting it in a way that I should have already thought of.
EDIT: Also, though that tire model works, it looks like it's more of a stand-in than an actual model for the 1/2" segments of Traction Tire that appear on the website. Will the actual traction tire models be released?
Never assume the motives of others are, to them, less noble than yours are to you. - John Perry Barlow
tumblr | twitter
'Snow Problem CAD Files: 2015 2016
MN FTC Field Manager, FTA, CSA, Emcee
FLL Maybe NXT Year (09-10) -> FRC 2220 (11-14) -> FTC 9205(14-?)/FRC 2667 (15-16)
VEXU UMN (2015-??)
Volunteer since 2011
2013 RCA Winner (North Star Regional) (2220)
2016 Connect Award Winner (North Super Regional and World Championship) (9205)
Last edited by cadandcookies : 13-12-2013 at 00:23. Reason: added question instead of posting again
  #183   Spotlight this post!
Unread 13-12-2013, 00:50
AndreaV AndreaV is offline
FRC #1360
AndreaV has a spectacular aura aboutAndreaV has a spectacular aura about
Will WCP continue to sell colsons in the future? Will Vex be stocking colson wheels at their distribution centers next season?
Apart from the new 3.25" versawheel, are there any plans to make wheels cheaper/easier to interface with 1/2 hex? right now the solution seems to be either two 1/2" hex versahub for @18/wheel, or a 1/2" versahub and a bearing for $14/wheel. 3.25" leaves you with little ground clearance, right now the best options seems to be 4" colsons, with 4" stealth wheels being the cheaper option.
  #184   Spotlight this post!
Unread 13-12-2013, 01:45
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Originally Posted by JVN View Post
Hi Sean,
Unfortunately, I don't have a data sheet to back this up. We spoke directly with a few belt manufacturers, off the record on this topic.
Of course those users who would prefer GT2 belts can purchase them from any number of suppliers. VEXpro has chosen HTD based on the feedback we received, and some simple preliminary testing.
If you have any concerns, feel free to email prosupport@vex.com to discuss further.
-John
Originally Posted by Jared341 View Post
Given that HTD is at this point a de-facto standard while GT2 is a proprietary profile*, I don't think a lot of belt manufacturers would want to go on the record with an unbiased recommendation. Gates is going to say that GT2 is the way to go, while everyone else will say HTD.
In reality, a wise designer would probably want to have enough of a safety margin that either profile would not ratchet.
* A brief Google search couldn't confirm or deny this, but it is my recollection. I'm sure that CD will correct my statement if it is incorrect
Everything I have seen in the Gates literature showes the GT2 profile ahead of HTD. Check out page 10 of the Gates Light Power and Precision manual. This shows the ratcheting torque of 5mm GT2 and HTD being evenly matched across a range of tensions tested at 2300 RPM (roughly 3X FRC drive train speeds), with GT2 being slightly better than HTD (<5% and decreases as tension increases).
The main advantage as I see it of GT2 over HTD is reduced backlash. In a light load test condition (as defined by Gates), the backlash on 3mm GT2 is 1/3 that of 3mm HTD (.012" vs .030"). This is because the GT2 profile is designed to have less clearance than the HTD profile.
Given the small performance difference as reported by Gates at the 5mm size, the FRC application, and the vendor feedback that Vex Pro got, HTD seems a reasonable choice. I look forward to having more timing belt and pulley sources. We will have to look into it more, but it looks like this offering may enable us to make our wheel modules using all Vex Pro products.
-Travis
  #185   Spotlight this post!
Unread 13-12-2013, 03:46
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Originally Posted by smistthegreat View Post
I'm not sure if this was intended with the design, but you should be able to find a 3-position cylinder to put on the bottom dog, letting you shift the drivetrain into a neutral gear (with the dog disengaged, between the two dog gears) when you want to engage the PTO.
Originally Posted by BBray_T1296 View Post
Oh yeah! I just remembered another thread wondering if there was a neutral for the ballshifter, and there was a link to the piston Im sure you are talking about. Thanks
BBray,
The intent of the product was to allow for a neutral IF teams wanted it.
http://puu.sh/5L9Hb/b016fcbd71.jpg
The cylinder mount allows to teams to use the current SMC pancake cylinder along with the Bimba/Fabco 2 position OR 3 position cylinder.
http://puu.sh/5L9I5/005faa9138.jpg
-RC
R.C.
MadTown Robotics Team 1323
  #186   Spotlight this post!
Unread 13-12-2013, 04:48
President, VEX Robotics, Inc.
If you order the one that says, "in stock" then it will ship same day if ordered before 3pm Central time. The "Ships before Kickoff" items are in the plating process right now and they will ship before January 4th.
Yes, the gears without the Versakey pattern still have the FRC standard mounting hole pattern. We made non-Versakey gears to save teams that don't need the Versakeys some money.
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
  #187   Spotlight this post!
Unread 13-12-2013, 08:44
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
That's the literature I found as well. Seems like if backlash isn't a concern, HTD should be fairly interchangeable, but I wouldn't say it is ever better performing than HTD.
Mentor 2415
  #188   Spotlight this post!
Unread 13-12-2013, 18:56
Steven Donow Steven Donow is offline
AKA: Scooby
Steven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond reputeSteven Donow has a reputation beyond repute
Here's something neat that I'd love to see from VEX: JVN's mechanical calculator as some sort of web app.
  #189   Spotlight this post!
Unread 13-12-2013, 19:01
And for the sake of convenience: A belt C-C calculator to help select which VEXPro stocked belts and pulleys to buy, right on the VEXPro website. Not hard to find elsewhere, but it'd be great for people who are new to designing for belts.
  #190   Spotlight this post!
Unread 13-12-2013, 19:04
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Seconded. This would be really, really helpful.
-Plutarch
  #191   Spotlight this post!
Unread 13-12-2013, 19:41
AKA: Nick Aarestad
Especially considering that the SDP/SI calculator doesn't actually have some of the belts that VexPro does.
tumblr | twitter
VEXU UMN (2015-??)
  #192   Spotlight this post!
Unread 13-12-2013, 19:47
AlecS AlecS is offline
FRC #1323 (Madtown Robotics)
AlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond reputeAlecS has a reputation beyond repute
Center distance calc now available here and will be on VEXpro's site soon.
Works for any size pulley, and gives out the two nearest VEXpro belt sizes, to the desired center distance. The pulley size also turns bold when you are using a VEXpro pulley. Any box that is white can be edited by the user, boxes that are gray are info from the calculator.
Alec S.
Engineer - Sales Representative, WestCoast Products || Twitter
  #193   Spotlight this post!
Unread 13-12-2013, 19:51
#TeamAlec
Thanks WCP!
  #194   Spotlight this post!
Unread 13-12-2013, 23:05
DampRobot's Avatar
Physics Major
AKA: Roger Romani
For all those who want to take a quick look at some of the new components without opeing the CAD, here are a few screenshots:
2 motor VersaPlanetary plates:
CIMile Cuttaway 1:
CIMile Cuttaway 2 (with mega cool output shaft/gear!):
WCD 3 CIM Ball Shifter:
WCD 3 CIM Ball Shifter Cutaway:
-Plutarch
  #195   Spotlight this post!
Unread 15-12-2013, 21:12
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
I've been playing around with VersaPlanetary CAD models today, and it has been a learning experience. They're really neat little boxes.
What holds a ring gear add-on stage to the new dual input gearbox? The STEP model shows a couple of 10-32 screws sticking out, but there is no threaded 10-32 hole to go into on the ring gear stage. The 10-32 screw would seem to go into the the cutout corners of the ring gear block. Does the ring gear's shoulder press fit into the plastic housing of the dual input?
This picture shows the 10-32 screws sticking out and not connecting to the ring gear. What have I missed?
I tried rotating the ring gear 90 degrees to use the other holes with 8-32 screws, but it looks like the distance between those 8-32 holes is less than 2", presumably to force people to assemble VersaPlanetary boxes correctly. This picture off the Vex Pro website shows the ring gear in the same orientation as I am trying to assemble it.
