Go to Post The GDC is the Grinch because they just stole my Christmas! - scottmacdonald [more]
Unread 13-12-2013, 18:51
Toa Circuit's Avatar
Toa Circuit Toa Circuit is offline
Thaddeus Maximus
AKA: Thad Hughes
FRC #4213 (MetalCow Robotics)
Toa Circuit is an unknown quantity at this point
Question PWM Connection Legality?
Would it be legal to connect just the PWM signal and ground from the Digital Sidecar to motor controllers? I know it works, but would it be legal?
Also, just as a thought, would it be possible just to connect the PWM signal (since everything is commonly grounded, right?)? (Would this be legal?)
2012 Head of Programming and Electrical
2013-14 Overall Team Captain and Programming Head
2012-14 Mentor of FLL Team Power Surge
2014 Dean's List Finalist
2014 CIR Xerox Creativity Award
Webpage
Unread 13-12-2013, 19:13
MaxMax161's Avatar
MaxMax161 MaxMax161 is offline
Allegedly Useful
AKA: Max Llewellyn
FRC #2791 (Shaker Robotics), FRC #1676 (Pascack π-oneers)
MaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond reputeMaxMax161 has a reputation beyond repute
Re: PWM Connection Legality?
It seems like the 2013 manual is no longer up and I don't have a copy handy. I'm not sure what it says specifically on the matter but I would expect it to be strongly discouraged if not illegal. I think it's also something an inspector could take issue with at an event. If I find a copy of the game manual I'll update you.
2791 Shaker Robotics (2013-present)
--Control Systems Mentor 2013-present
--Drive coach 2015-present
1676 The Pascack π-oneers (2010-2013)
--Drive coach 2011-2013
--Lead Programmer 2011-2013
Unread 13-12-2013, 19:24
EricH EricH is online now
Look in the archived documentation, same place on the FIRST site as the Manual.
Unread 13-12-2013, 19:25
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
The 2013 manual is still on the FIRST web page it's just under the archived section: http://www.usfirst.org/roboticsprogr...-event-results
I know that you must control all motors using a FIRST approved motor controller or spike relay. The only execption is controlling a servo. Then that is connected directly to the side car, with the jumper added to put power to the PWM cable.
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
Unread 13-12-2013, 19:32
MaxMax161's Avatar
Allegedly Useful
AKA: Max Llewellyn
Thanks didn't know about that!
Anyway quick search through the manual leads me to this
4.1.9.13 R67
Every relay module, servo, and PWM motor controller shall be connected via PWM cable to the Digital Sidecar and be
controlled by signals provided from the cRIO via the Digital Sidecar. They shall not be controlled by signals from any
other source.
I think the issue would be an incomplete PWM cable is not a PWM cable and therefore illegal to connect speed controllers and the digital sidecar with.
Out of curiosity what brings up your question?
Unread 13-12-2013, 19:40
FWIW, inside the motor controller (unlike a servo) there is no connection to the PWM power pin.
Unread 13-12-2013, 20:09
In addition, the PWM ground and signal inputs are connected to an opto-isolator. This is at least how it is implemented on the Jaguar for sure, I have seen evidence on the Talon that this is also true, and I would expect the same for the Victor. This means that ground on the PWM cable isn't the same ground as the speed controller ground. Which is a good thing, since it breaks what would otherwise be a nasty ground loop.
Unread 13-12-2013, 20:27
You would severely limit the current available for the motor controller by using the DSC as a power common. Not only that, the DSC would then be forced to generate noise as the DSC common varies with motor usage. Remember there is no "ground" on the robot. There is only power common which is something altogether different. As all motor current returns to the battery through normal (two wire branch circuits) wiring to the PD, noise is not a problem for the DSC, Crio or the radio in most cases.
Also for all the newbies lurking here, the robot frame may not be used as a power pathway. You must provide two wires to all loads connected to the battery and they must be insulated from the frame.
Unread 14-12-2013, 14:30
nuttle nuttle is offline
AKA: Allen Nuttle
FRC #4080
nuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud ofnuttle has much to be proud of
In addition, unless you place a jumper to get 6V on the power wire (when using a servo, for example), the power wire is not connected at the DSC. Spikes and (I suspect) all motor controllers use an opto-isolator, so by design there is no common ground. You have to use ground and signal but there is no need for the power wire. Note that for a Spike, there is actually one ground and two signal wires and the signals are on/off only (there is no Pulse-Width Modulation happening and this is why there are separate places for Spikes and motor controllers/servos to plug into the DSC), even though you see this called a PWM cable. When wiring a Spike for the compressor, my personal opinion is it is good practice to only connect the signal for the forward direction, so there is no way to run the compressor in reverse (which is very bad for most compressors). When we've made and used custom cables, we always only included the required number of wires and never had this come up in an inspection, FWIW.
