Go to Post I am sorry if something was missed at your regional, it will be checked at this event. - Al Skierkiewicz [more]
Unread 14-12-2013, 16:20
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Talking Making molds!
We've noticed a few teams would make molds for thing on their robot. We were wondering how they created them. What was the process and can we get a tutorial!
Unread 14-12-2013, 16:39
Re: Making molds!
Brandon Holley posted some decent information here: http://www.chiefdelphi.com/media/photos/34720
This website would also be very helpful.
http://www.smooth-on.com/howto.php
Unread 14-12-2013, 17:23
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Making molds!
or leave some bread in a damp place...
Seriously: The smooth-on site is awesome, buy one of their starter kits and play around. It can get expensive to make big molds, but the starter kit is around $35 and you can make a bunch of cool stuff with it, and more importantly understand the process.
Also, if inexpensive is important, get some plaster of paris and make molds for wax (or, use wax to make molds for plaster). Using flexible silicone has its advantages, but cost isn't one of them. Plaster is cheap and reliable.
Unread 14-12-2013, 20:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Making molds!
Is there an easy way to take a 3D CAD file, turn it into a 3D CAD file of the inverse of the object to make a mold, and then 3D print a mold, then pour urethane or something to cast the object from? Can you cast urethane directly in an ABS or a PLA mold?
Also, I'm lost on how to invert a CAD model to be basically a block with the negative of an object.
Unread 14-12-2013, 20:47
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Re: Making molds!
There's a tab in SolidWorks called Mold Tools. Start with the tool called Parting Lines, and move to the right with tools in sequence until you get your mold.
-Plutarch
Unread 14-12-2013, 20:49
Re: Making molds!
Anyone have experience doing this in Inventor?
Unread 14-12-2013, 22:12
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: Making molds!
You can use the "Combine" command in the modeling tool bar to add, subtract, or intersect one body from another.
Create a mold body such as a rectangular block. Import another part with the Derive command, and select the option to maintain it as a separate body. Move it as needed with the Move Bodies command. Select Combine, indicate the base body (block) and the tool body (part) and indicate cut/subtract. Should cut the tool body volume from the base body.
PS edit: I do not see a way to rotate/reorient the part body after importing it into the mold file. Only translation moves. It may be necessary to make sure the mold body and part body are already in the proper orientation respectively.
Unread 14-12-2013, 22:16
safiq10's Avatar
Re: Making molds!
If someone has experience in making molds and can make a video tutorial for FRC either in solidworks or inventor they'd be my hero. (I've looked tutorial for how to do this they were very confusing and not very helpful)
Unread 14-12-2013, 23:00
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Re: Making molds!
Hmmm, well I'm not doing anything tomorrow...
I might just do that. However, I don't really know much about the urethane casting process. I can teach how to use the tools in Solidworks, but I don't know if there are special considerations that need to be accounted for in the mold design, (Besides adding draft, eliminating undercuts and such, I've designed an injection mold before.)
FRC #1306 - BadgerBOTS - Mechanical/Machining/Safety/Marketing Mentor
FTC #6806 - Ratchet Robotics - Head/Founding Mentor
2010 - Wisconsin Regional Chairman's Award Winner - Wisconsin Regional Quarter-finalist - Curie Division #5 Seed, Quarter-finalist
2011 - Wisconsin Regional Innovation in Control Award Winner - Wisconsin Regional Quarter-finalist
2012 - Wisconsin Regional Engineering Inspiration Award Winner - Wisconsin Regional Semi-finalist
2013 - Wisconsin Regional Chairman's Award Winner
Unread 18-12-2013, 19:03
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Making molds!
Although there are many types of urethane, generally it is a pourable 2-part compound that is somewhat viscous, a little thinner than honey, but thicker than pancake syrup. It warms a little while curing, and shrinks a little especially in thicker casts.
Both ABS and PLA have enough temperature resistance to take a direct casting of most urethane. Surface finish may be less than desirable, and mold release agent is mandatory.
Unread 18-12-2013, 20:51
itsjustmrb itsjustmrb is offline
FRC #4063 (TRikzR4kiDz)
itsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to beholditsjustmrb is a splendid one to behold
Re: Making molds!
Make your assembly and save it. Next open a new .ipt and choose the derive component from the import panel. It will import you assembly and the you change the + to - on the part you want to delete/erase and the new derived part will be your mold.
Mr. B
2016 Hub City Regional Winner #3 Seed (3310 & 4301)
2016 Bayou Regional Winner #1 Seed (233 & 4087)
2015 Dallas & Alamo Creativity Award
2015-2016 Hub City Regional Gracious Professionalism
2014 Hub City Regional Engineering Inspiration
2012-2016 Alamo Regional Gracious Professionalism
2016 Bayou Regional Gracious Professionalism
2014 Dallas Regional Gracious Professionalism
2013 Alamo Regional Winners (2468 & 2789)
Unread 18-12-2013, 22:05
yash101 yash101 is offline
AKA: null
Re: Making molds!
Off topic:
That was a good one.
And of course, the image below (I've saved it cause I need to use it so often )
Name:	Screen Shot 2013-12-18 at 8.01.04 PM.png
Unread 18-12-2013, 22:57
safiq10's Avatar
Re: Making molds!
Thank you too all who have answered. We are currently 3d printing a wheel for our FTC team and they will be making a urethane mold from it. I will try to keep you up to date on it. If you have any suggestions or any comments or tips please ask or comment. I'm learning so much from this and I'm sure someone else is too. So thank you
Unread 18-12-2013, 23:37
DuaneB's Avatar
DuaneB DuaneB is offline
FRC #1731
DuaneB is an unknown quantity at this point
Re: Making molds!
Freeman Supply has a free DVD you can request, which shows molding and casting techniques using some of their products.
http://www.freemansupply.com/dvd/
Smooth-On and Tap Plastics have You Tube channels demonstrating applications of their molding and casting products.
http://www.youtube.com/user/SmoothOnInc
http://www.youtube.com/user/tapplastics
Unread 19-12-2013, 14:53
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
Re: Making molds!
Here's our attempt at cast urethane tread a couple of seasons ago. The mold was 3D printed in ABS (in 4 pieces). The resultant "flashing" was minor and easily removed with a razor blade. We used a 2-part 50A durometer urethane from Eager Polymers (Part # EP-1150). The surface finish was adequate, but you can improve it with a little sanding and acetone.
FRC Team 3489 "Category 5"
