Go to Post I fear not the drive team who has practiced 10,000 defenses once, but I fear the drive team who has practiced one defense 10,000 times. -Bruce Lee - bEdhEd [more]
Unread 14-12-2013, 22:18
LittleRed's Avatar
LittleRed LittleRed is offline
AKA: Brian Davenport
FRC #3824
LittleRed will become famous soon enough
Re: 1325's First 3D Printed Gear!
Originally Posted by luckof13 View Post
What are you basing this on? What printable polymer is as "strong as Aluminum"? My high school just got a $40,000 printer that prints ABS. According to the spec sheet, that has tensile strength of 37MPa. By comparison, my Materials Science textbook says that Aluminum has a tensile strength of 90MPa. Please provide support for your claims.
It isn't quite the strength of aluminum, but ULTEM has a tensile strength of 71.6MPa.
FRC 3824 Student: 2012-2014
Unread 14-12-2013, 22:27
pfreivald's Avatar
AKA: Patrick Freivald
How about steel?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-12-2013, 22:41
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
True, but printers capable of printing that cost much more than most schools can afford. Although, I know there is at least one team (blanking on the number) that uses this with great success.
How about steel?
I did see this a few days ago. Once the technology is improved upon, it looks like it could be very promising.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 14-12-2013, 23:11
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
$40k to print ABS? They probably purchased an Objet or similar that best uses FDM or Polyjet to much higher res and precision. You can probably get much cleaner tolerances with that printer compared to a Makerbot, Reprap, Cube, desktop printer but obviously at high cost.
Anyway we tried to print hubs last year but the motors tore them apart very quickly. Larger gears may work just fine as long as the gears dont have to absorb large loads (for example in a drive train, holding up robot weight on a large arm, etc). 3D printed gears would work just find for conveyors and the like, but pulleys would work even better.
The other issue is ABS and especially PLA tend to melt and warp if you attempted to drill a hole in them post-printing, so make sure the shaft size is correct the first time. Quick hint: on my Rep2 I increase the desired shaft bore diameter by 0.05in because the plastic tends to expand. Drilling out a larger bore will melt the plastic.
I recommend you test some of the print parameters and see what lasts the longest. For example, try adding additional shells and infill ratios, consider reducing your Z layer height, and even try printing in different orientations (vertical vs horizontal, etc).
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 14-12-2013, 23:16
seg9585's Avatar
AKA: Eric
Oh, and regarding material: PLA and ABS is generally the most common but you can also print in nylon. This is good for timing belts since it's bendable:
http://eric.segonline.net/2013/3dprints/timingbelt2.jpg
I haven't tried the Makerbot "Flexible PLA" yet, but I'm looking forward to testing it out!
Then there's always LAYWOOD, which apparently smells and looks like wood:
http://www.fabberworld.com/Laywood-D...3-00:::10.html
My FIRST legacy:
Unread 15-12-2013, 00:02
Brandon Holley's Avatar
Objets are quite pricey. The one we have at work was well north of 200k. 40k sounds right about in the Fortus 250 or Dimension range as far as price goes.
I've had no problem drilling out ABS printed parts in the past. I actually drilled a bunch of holes out today. FDM printed parts (particularly ABS parts) are actually really good at secondary operations such as drilling, pressing in brass inserts, and sanding. They often hold up much better than Objet or SLA'd parts.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 15-12-2013, 00:03
Chris_Ely's Avatar
AKA: luckof13
I believe the model is a Dimension1200se, but I don't know for sure. I don't know much about the printer since I graduated after it was purchased.
Unread 15-12-2013, 00:05
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Maybe the team that partnered with Oak Ridge Lab
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 15-12-2013, 00:11
Chris_Ely's Avatar
AKA: luckof13
That's who I was thinking of. I just searched. It is team 3824. I saw their robot at Champs last year. Very cool use of the high grade printers.
