Go to Post FRC is a big tent. There's room for everybody. - Ether [more]
Unread 09-02-2003, 18:37
Neal Turett Neal Turett is offline
Neal Turett is on a distinguished road
Question Which sensor?
I need a sensor much like a potentiometer, but one that measures linear distance instead of rotation. For example, one that I could attach to a pneumatic cylinder to know where it is.
While browsing the Digikey catalog for something that would work, I came across a "Distance Measuring Sensor" from Sharp. Has anyone used these? Would this do what I need, and could I just run it to an analog input?
Unread 09-02-2003, 21:13
ttedrow's Avatar
ttedrow ttedrow is offline
Herding electrons
AKA: Tim Tedrow
FRC #0281 (EnTech)
ttedrow will become famous soon enoughttedrow will become famous soon enough
I took a quick look at one of the spec sheets. I think that one of these units would work for you application. Vcc is +5vdc and the output is ~ .4vdc to 2.5vdc giving you a range. This can be used in an analog input. The output is not liner so be careful with the programming.
Good luck
Tim Tedrow
Sr. Design Engineer
Caterpillar Inc.
Greenville, SC
KD4EGM
FRC 281 Greenvillains
Infected with the FIRST virus in 2000
Yes, Chute Door!!!
Unread 10-02-2003, 08:20
Why not just use two micro switches, actuated by the connection hardware to the cylinder? If you need infinite control over the position, the pot is the best way.
Unread 10-02-2003, 08:58
Before going into a long search for measuring extension of a piston, see if you can stop the piston at partial extension, and then check that when it gets there, and you lock it, that there is enough force available to hold the position.
Stopping it where you want it may be easy if the piston is slow (forget flow restrictiers, with those SMC valves how could it be fast?), but locking in that position is hotly debated elsewhere. Many say it can be done, but I don't see many "On our robot , we did thus and so, to get the effect..."
The worst idea may be using those self-coiling springs mounted in a slot in a 10-turn pot's shaft, the far end attatched to the far end (of the piston).
Unread 10-02-2003, 09:01
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Well, our idea doesn't exactly center around a pneumatic cylinder. It was just an example. I guess a closer application would be measuring the extension of a lead screw. We want a sensor that would measure a short linear distance. Like a pot, but measuring linear instead of rotational motion.
Jeff Waegelin
Unread 10-02-2003, 09:53
Microswitches is still the best bet on a lead screw. If it is a short distance and is capable of a gear reduction down to 270 degrees of rotation you can use a single turn pot. There are also 3, 5, and 10 turn pots available that you can attach to the lead screw, but accuracy may suffer due to the A/D in the robot controller. You will have to figure out the quantization of 256 counts vs. rotation or distance traveled to determine if a multiturn pot would work OK for you.
Reflective tape sensor? scitobor 617 Electrical 2 19-11-2003 08:51
sensor doesn't work PBoss Programming 7 29-01-2003 18:39
Sensor or no Sensor For Autonomous mode Kyle1010 Programming 14 22-01-2003 13:10
How do you connect optical sensor? archiver 2001 1 23-06-2002 23:05
Optical range sensor Ben Mitchell Technical Discussion 9 12-01-2002 00:11
