Go to Post You can take my blocker... but you can never take my cheesecake! - Andrew Schreiber [more]
Unread 14-12-2013, 14:32
K519_1325's Avatar
K519_1325 K519_1325 is offline
AKA: Karan Guglani
FRC #1325 (Inverse Paradox)
K519_1325 is an unknown quantity at this point
1325's First 3D Printed Gear!
We were recently sponsored by Robo3D, a new company that makes 3D Printers. They have provided our team with a 3D Printer that we used today to make our first gear that we used for our shooter.
The gear did not last too long but it held up surprisingly well. This is a first iteration and we plan to make it a lot better.
ID:	15553  Click image for larger version
http://www.team1325.com
Unread 14-12-2013, 14:59
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: 1325's First 3D Printed Gear!
Our team found 3D printed parts to be good for low stress custom parts. We used gears connected to a potentiometer on our shooter. 3 competitions and no failure.
Anything with shearing stress probably wont survive long.
Unread 14-12-2013, 15:19
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Do you have a picture??
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 14-12-2013, 16:00
SenorZ's Avatar
Physics Teacher
AKA: Tom Zook
Here are a couple of pics from our 2013 robot. The gears were on the robot through 3 competitions (2 regionals and Championships)
I'm pretty sure the cam for the shooter was put on at our second regional to replace one that didn't work well at our first regional.
In both cases, no breakage because they were not under high stress.
https://plus.google.com/photos/10807...1/albums/posts
Unread 14-12-2013, 17:22
K519_1325's Avatar
AKA: Karan Guglani
Without a doubt the parts we print are going to be used in minimal stress situations. Just out of curiosity, what plastics do teams use to print? Our printer can only print PLA components.
Unread 14-12-2013, 21:52
yash101 yash101 is offline
AKA: null
Most printers support either PLA or ABS or both. However, there are some more expensive ones that support different materials, sometimes as strong as Aluminum!
We print in ABS
Unread 14-12-2013, 22:03
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
We print in ABS
What are you basing this on? What printable polymer is as "strong as Aluminum"? My high school just got a $40,000 printer that prints ABS. According to the spec sheet, that has tensile strength of 37MPa. By comparison, my Materials Science textbook says that Aluminum has a tensile strength of 90MPa. Please provide support for your claims.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 14-12-2013, 22:18
LittleRed's Avatar
LittleRed LittleRed is offline
AKA: Brian Davenport
FRC #3824
LittleRed will become famous soon enough
It isn't quite the strength of aluminum, but ULTEM has a tensile strength of 71.6MPa.
FRC 3824 Student: 2012-2014
Unread 14-12-2013, 22:27
pfreivald's Avatar
AKA: Patrick Freivald
How about steel?
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 14-12-2013, 22:41
Chris_Ely's Avatar
AKA: luckof13
True, but printers capable of printing that cost much more than most schools can afford. Although, I know there is at least one team (blanking on the number) that uses this with great success.
How about steel?
I did see this a few days ago. Once the technology is improved upon, it looks like it could be very promising.
Unread 14-12-2013, 23:11
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
$40k to print ABS? They probably purchased an Objet or similar that best uses FDM or Polyjet to much higher res and precision. You can probably get much cleaner tolerances with that printer compared to a Makerbot, Reprap, Cube, desktop printer but obviously at high cost.
Anyway we tried to print hubs last year but the motors tore them apart very quickly. Larger gears may work just fine as long as the gears dont have to absorb large loads (for example in a drive train, holding up robot weight on a large arm, etc). 3D printed gears would work just find for conveyors and the like, but pulleys would work even better.
The other issue is ABS and especially PLA tend to melt and warp if you attempted to drill a hole in them post-printing, so make sure the shaft size is correct the first time. Quick hint: on my Rep2 I increase the desired shaft bore diameter by 0.05in because the plastic tends to expand. Drilling out a larger bore will melt the plastic.
I recommend you test some of the print parameters and see what lasts the longest. For example, try adding additional shells and infill ratios, consider reducing your Z layer height, and even try printing in different orientations (vertical vs horizontal, etc).
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 14-12-2013, 23:16
seg9585's Avatar
AKA: Eric
Oh, and regarding material: PLA and ABS is generally the most common but you can also print in nylon. This is good for timing belts since it's bendable:
http://eric.segonline.net/2013/3dprints/timingbelt2.jpg
I haven't tried the Makerbot "Flexible PLA" yet, but I'm looking forward to testing it out!
Then there's always LAYWOOD, which apparently smells and looks like wood:
http://www.fabberworld.com/Laywood-D...3-00:::10.html
My FIRST legacy:
Unread 15-12-2013, 00:02
Brandon Holley's Avatar
Objets are quite pricey. The one we have at work was well north of 200k. 40k sounds right about in the Fortus 250 or Dimension range as far as price goes.
I've had no problem drilling out ABS printed parts in the past. I actually drilled a bunch of holes out today. FDM printed parts (particularly ABS parts) are actually really good at secondary operations such as drilling, pressing in brass inserts, and sanding. They often hold up much better than Objet or SLA'd parts.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 15-12-2013, 00:03
Chris_Ely's Avatar
AKA: luckof13
I believe the model is a Dimension1200se, but I don't know for sure. I don't know much about the printer since I graduated after it was purchased.
Unread 15-12-2013, 00:05
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Maybe the team that partnered with Oak Ridge Lab
