Go to Post Mentors can't get tired, it says so in the manual. SENIOR mentors, therefore, must have a different manual! - KathieK [more]
Unread 15-12-2013, 11:33
Physics Quiz 9
Given:
Robot with 4 standard (non-omni non-mec) wheels.
No drivetrain (no gearbox, no chains; just wheels with frictionless bearings)
Total mass of robot *including the wheels* is Mrobot
Total mass of the 4 wheels is Mwheels
Assume that when you push the robot, the wheels rotate (instead of sliding on the floor)
Assume that the mass of the wheels is evenly distributed,
like a solid disc rather than a hoop.
Problem:
Find the "equivalent mass", Me, such that
F = Me*a
...where "a" is the acceleration and "F" is the pushing force.
Unread 15-12-2013, 12:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Physics Quiz 9
Me = Mrobot + 0.5*Mwheels
I have the solution steps (on 3 post-it notes), but I'd like to see if this is correct first.
Unread 15-12-2013, 12:14
SenorZ's Avatar
SenorZ SenorZ is offline
Physics Teacher
AKA: Tom Zook
FRC #4276 (Surf City Vikings)
SenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond reputeSenorZ has a reputation beyond repute
Re: Physics Quiz 9
I'm getting Mwheel/2
Unread 15-12-2013, 13:28
T^2 T^2 is offline
FRC #5499
Re: Physics Quiz 9
Let F_linear be the force that accelerates the robot body, and F_angular be the force that accelerates the rotation of the wheels. F_linear + F_angular = F.
F_linear = (M_robot)(a)
F_angular = tau/r = 0.5(M_wheel)(r)(alpha) = 0.5(M_wheel)(a) where r is wheel radius and alpha is angular acceleration
M_e = (F_linear + F_angular)/a = ((M_robot)(a) + 0.5(M_wheel)(a))/a = M_robot + 0.5(M_wheel)
Not sure if I used M_robot in the equation correctly.
Unread 15-12-2013, 13:29
TRWSHSHLX TRWSHSHLX is offline
AKA: Henry Lei
TRWSHSHLX is an unknown quantity at this point
Re: Physics Quiz 9
Second sanddrag.
Thank you for posting this quiz so I can review my kinematics and procrastinate for a bit .
Unread 15-12-2013, 14:12
Re: Physics Quiz 9
That was quick. Nice work guys.
An am-0940 wheel weighs about 0.5 lb. So the extra force due to wheel rotation required to accelerate a 150 lb robot amounts to less than 1%.
Unread 15-12-2013, 14:41
Re: Physics Quiz 9
This was a fun one, because it has been YEARS since I've done something like this. I did conceptual Physics in 2001, AP Physics in 2003, and Physics for three quarters in college in 2005, and then finished my Mechanical Engineering degree in 2010, but I haven't done a whole lot of this type of problem solving since. I had a very rough idea of the concepts going on here, and I recalled a few things from school, but I had to look up the moment of inertia equation for a solid cylinder, and I had to remind myself that Tau = I*alpha.
Initially, I had misread the problem to think that Mwheels was the weight of each wheel, so my answer was 4 times too large, which I quicklyrevised.
Thanks for making me think on a Sunday morning.
Unread 15-12-2013, 15:20
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Physics Quiz 9
If anyone's interested, here's a somewhat similar, slightly tricky question I recall from a classical mechanics course:
A bowler releases a bowling ball. Initially, it is sliding at velocity v. Due to friction with the ground, it begins to roll. What is the velocity of the ball once it is rolling?
Hint: Not all origin locations are created equal.
"The breakfast of champions!"
Unread 15-12-2013, 15:45
magnets's Avatar
magnets magnets is offline
Re: Physics Quiz 9
I don't think you've given enough information. I am fairly certain (but may be wrong) that the force of friction on the ball is important, so we'd need to know the mass/friction.
Unread 15-12-2013, 15:55
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Re: Physics Quiz 9
Should we assume the bowling ball is a solid sphere? Because as a league bowler I'm well aware they are not :-)
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
Unread 15-12-2013, 16:10
James Kuszmaul James Kuszmaul is online now
NEFIRST CSA
FRC #0971 (Spartan Robotics)
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
Re: Physics Quiz 9
Well, once the bowling ball is rolling, you will have an angular momentum:
L = I * omega
and a momentum:
p = m * vf
where vf = omega * r
This angular momentum must result from some constant force of kinetic friction, fk acting over a time, t, at the radius r such that:
fk * r * t = L
This same force of friction will have created an impulse, which slowed down the ball as a whole:
fk * t = m * vf - m * v
I * omega / r = m * (vf - v)
I * vf = m * (vf - v)
and so:
vf = -mv / (I - m)
if we take the bowling ball to actually be a perfect, uniform sphere, then:
vf = -mv / (.4 * m * r2 - m)
so
vf = -v / (.4 * r2 - 1)
Which looks really weird to me, so I have no idea if it is correct.
Edit: Figured out two issues. I forgot a negative sign on the change in translational momentum and I switched where the r should go when converting between angular and linear velocity.
Starting from:
I * omega / r = -m * (vf - v)
omega = vf/r
I * vf / r2 = -m * (vf - v)
vf = mv / (I / r2 + m)
Assuming uniform sphere:
vf = mv / (0.4 * m * r2 / r2 + m)
vf = v / (0.4 + 1)
vf = 5 * v / 7
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
Unread 15-12-2013, 16:22
AKA: Eli Barnett
Re: Physics Quiz 9
Yes, you should assume that.
Nope, not quite! You're making it a bit harder than it has to be by attempting to calculate from the forces themselves - rather, try to think of a way that you can find the answer simply by analyzing the system in two states only (initial, and final). Placement of the origin is crucial to simplifying the problem.
Unread 15-12-2013, 16:24
seg9585's Avatar
AKA: Eric
Re: Physics Quiz 9
Assuming a solid sphere, I get a final velocity v2 = 5/7*v1
Using conservation of momentum:
m*v1*R = I*omega
omega = v2/R (ball rolling v2 = r*omega)
I = I_sphere + I_point mass = 2/5*m*R^2 + m*R^2 = 7/5*m*R^2 (parallel axis theorem)
m*v1*R = 7/5*m*R^2 * v2/R
m, R both cancel
v1 = 7/5*v2 --> v2 = 5/7*v1
My FIRST legacy:
Unread 15-12-2013, 16:40
NEFIRST CSA
Re: Physics Quiz 9
I'm not entirely sure what you mean by trying "to calculate from the forces themselves" (I only mentioned a force at all so that I could create the equivalency; there may be some convenient equation that already takes that into account). My issues resulted from a couple of silly mental errors in typing out the solution (I shouldn't solve equations in text editors).
Unread 15-12-2013, 16:48
AKA: Eli Barnett
Re: Physics Quiz 9
I was trying to get at that if you place your origin on the floor, you can notice that the friction force is pointing towards the origin and thus angular momentum is conserved; you need not not consider any forces in any capacity past that, only the initial and final velocities.
m*v1*R = I*omega
m, R both cancel
This is correct.
