Go to Post OK guys, the robot's overweight. You know the drill. - DonRotolo [more]
Unread 12-15-2013, 08:25 PM
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
pic: 18 Tooth #25 Sprockets Inside VersaChassis
Unread 12-15-2013, 08:29 PM
billbo911's Avatar
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
Re: pic: 18 Tooth #25 Sprockets Inside VersaChassis
Originally Posted by AlecMataloni View Post
With the sprocket and chain installed, how much clearance do you have between the chain and inner wall of the tube?
Unread 12-15-2013, 08:43 PM
Excellence is Bliss
SolidWorks tells me it'd be around .055" clearance vertically without chain installed. I don't know off the top of my head how much the chain would extend past the teeth. Either way, it's a cozy fit, but it "works" in CAD (granted, that's not a guarantee of success). I'll have the opportunity to test it using real parts sometime in the future, so i'll post results when I get the opportunity to mock it up.
Unread 12-15-2013, 08:44 PM
AdamHeard's Avatar
Lead Mentor
The 16T sprockets are plenty big for 4" wheels and give you a tad more clearance.
Unread 12-15-2013, 09:21 PM
Excellence is Bliss
Really, now... I wasn't sure if 16T would be big enough.
Unread 12-16-2013, 02:31 AM
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Do you have right to left clearance in those tubes to run dual sprockets on one shaft with the .1 wall thickness? I tried last season for our shooter gear box but had to make two plates instead of using our 1x3x.125 Al box.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 12-16-2013, 08:19 AM
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Nice looking model.
We have been putting 16T #25 chain inside 2 x 1.5 tube for a couple of years. If you want to do a drop center 16T is as small as you can really go. Your chain will start to stretch and loosen up, rub a bit against the wall of the tube. Assembly of 18T will be almost impossible and if you are just running a 1:1 ratio between wheels why go with an 18T?
I really believe Versa is going to really change things for teams with limited fabrication abilities.
Unread 12-16-2013, 08:45 AM
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
Originally Posted by rees2001 View Post
Nice looking model.
The main reason for going with a higher tooth count sprocket is to reduce the load in the chain and increase # of teeth that are meshed. Both influence how robust the system will be.
Mentor 2415
Unread 12-16-2013, 04:14 PM
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Two strands of #25 fit side-by-side inside a standard "1x2"x.125" wall tube.
We use 17 tooth double sprockets inside of our SimpleTube Chassis.
You cannot have any drop in this setup because of clearance around the chain.
Otherwise the system is great and is a nice volume save. FRC118 used this same setup for 2013 with zero failures and maintenance issues.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 12-17-2013, 05:31 PM
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
How do you get away without any drop? No problems turning?
Mike Schreiber
Kettering University ('09-'13) University of Michigan ('14-'18?)
FLL ('01-'02), FRC Team 27 ('06-'09), Team 397 ('10), Team 3450/314 ('11), Team 67 ('14-'??)
Unread 12-17-2013, 05:42 PM
They had different diameter wheels. Pretty cool stuff!
