Go to Post IYou might get it all changed over and discover your robot has trouble moving from a dead stop, can no longer turn without playing morse code on the breakers... - KenWittlief [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
  #91   Spotlight this post!
Unread 16-12-2013, 01:34
Scott L.'s Avatar
Scott L. Scott L. is offline
FRC #0222 (Tigertrons)
Scott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really niceScott L. is just really nice
Send a message via AIM to Scott L.
Talking Re: Internet at Competitions
Bluetooth operated in the 2.4GHz Range, The first channel starts at 2402 MHz and continues up to 2480 MHz in 1 MHz steps. So this could be a source of interference.
You can do anything, if you put your mind to it!!!
http://asp.shinraikon.com
  #92   Spotlight this post!
Unread 17-12-2013, 09:43
rsegrest's Avatar
rsegrest rsegrest is offline
@ least I'm OVER the rock THIS time
FRC #2582 (PantherBots)
rsegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant futurersegrest has a brilliant future
Originally Posted by techhelpbb View Post
Not quite what happened.
He found a hole and after they refused to address it he exploited it again.
Finding the problem: not the problem.
Bringing the problem to someone's attention (could have been done in a more polite and responsible manner): sort of a problem.
Opening the door to becoming an interloper on the field < entirely unacceptable.
Once he knew it was a problem and was asked to stop it was time to comply.
So the message here: if they ask you to stop - you stop.
Watch carefully - when Al says don't use hot glue on electronic motor controls I do not.
It does not matter if I agree - do not turn a simple disagreement into a war that has far reaching consequences.
On the other side of that: if someone tells FIRST respectfully there's a problem - they need to listen (usually they do).
FIRST did investigate the problem at great expense so obviously they are listening to this now.
(Keep in mind the goal is to evolve - mistakes happen - let's try to keep the disasters to a minimum.)
Thank you for the clarification. I was under the impression the individual found the hole and decided to randomly mess with people and was unaware that they had pointed it out to FIRST. And I completely agree with your comments on Al. I have often posted questions to him on Delphi to get a seasoned expert inspectors opinion!
Impossible is just a big word for small men who find it easier to live in the world they've been given than to explore the power they have to change it. Impossible is not a fact. It's an opinion. Impossible is not a declaration. It's a dare Impossible is potential. Impossible is temporary. Impossible is nothing.
~ Unknown
  #93   Spotlight this post!
Unread 17-12-2013, 10:07
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
There are things worth having a heated debate about: things that do great harm to FIRST like interfering with the fields and radios.
There are things not worth having a heated debate about: whether or not hot glue to hold PWM wires is legal. It makes little difference as long as the need to hold the wires is acknowledged and an acceptable alternative is offered.
I often seem to be argumentative when in reality I just want clarity as to avoid further conflict. When a team shows up to events you are not always dealing with the same people. There can be inconsistency introduced and that is confusing and impacts the quality of performance for everyone. In this case Al is a resource that offers consistency because the inspectors generally answer to him as lead inspector. Although Al can't officially dictate rules like the GDC can it makes little sense to document a disagreement with him unless there is a real risk to make it worth it. That said I do want to thank Al for his time because his role is not an easy one.
It is important for FIRST to be consistent on some things. Interfering with the fields is one of them. If you know you can interfere you should not do it without FIRST's consent as a test. The same would be true as a spectator that is not aligned to a team. In this case at least there was something FIRST could extract as a form of punishment. As a spectator I guess the best they can do is take your name, information and toss you out of the venue.
I am not clear if there is an official response to this sort of interference in the future. At the moment it seems to be an optional response. With the field as it is I suspect that eventually FIRST will have to make some decisions about what is the proper response to a problem such as field interference so there is clarity on what is to be done. Otherwise I perceive the potential for conflict that is not managed with the guidance of FIRST from the top, down.
[IMG] code is Off
