Go to Post While science and technology can solve difficult problems, it is people and interaction that make it all work. - DonRotolo [more]
Unread 12-16-2013, 08:19 AM
rees2001 rees2001 is offline
AKA: Rees
FRC #0340 (Greater Rochester Robotics)
rees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond reputerees2001 has a reputation beyond repute
Re: pic: 18 Tooth #25 Sprockets Inside VersaChassis
Nice looking model.
We have been putting 16T #25 chain inside 2 x 1.5 tube for a couple of years. If you want to do a drop center 16T is as small as you can really go. Your chain will start to stretch and loosen up, rub a bit against the wall of the tube. Assembly of 18T will be almost impossible and if you are just running a 1:1 ratio between wheels why go with an 18T?
I really believe Versa is going to really change things for teams with limited fabrication abilities.
