Go to Post As to "no fasteners," I have a gallon of epoxy, and I'm not afraid to spread it. - Rick TYler [more]
Unread 16-12-2013, 16:12
Darthjawafett Darthjawafett is offline
FRC #3059
Darthjawafett is an unknown quantity at this point
[FTC] Robot Control Configuration
Alright so. We are trying to set the robot's motor for a lift to a button. When trying to control it for time. (Driver doesn't want it set to a analog stick) (Distance didn't work too well because the distance is too short.) It generally listens half of the time. When it doesn't listen it moves constantly. Any solutions
Unread 22-12-2013, 21:52
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Re: [FTC] Robot Control Configuration
I'm not too sure about FTC, but in our LabVIEW program last year, we had multiple values being updated to one motor controller at the same time. This causes the program to "toggle" quickly between the two values and not choose just one.
Go through the code you have running at the time you encounter the error and make sure you're not setting a motor value twice at the same time (maybe having a button value and an analog value setting the same motor).
Good luck!
Per Audacia Ad Astra
