Go to Post Before joining FIRST, I sure wanted to be SUPERMAN or SPIDER MAN!....but after joining FIRST, I realized that there are other ways I can help people and the world. - RoboMadi [more]
Unread 16-12-2013, 18:28
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Refreshing fasteners
Are team has run out of fasteners and we are planning on refreshing them before build season. What sizes do you recommend getting?
2016: FRC 865 Mentor
Unread 16-12-2013, 18:35
yash101 yash101 is offline
AKA: null
Re: Refreshing fasteners
I'm no expert, but I learned last year, try to have all fasteners work with the same screwdriver size/wrench size, etc. That way, you won't have to keep getting a different wrench for different bolts. We have some special-colored tape on our main wrenches so it is easier to recognize them!
Unread 16-12-2013, 18:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Small! We use a lot of #10 and 1/4" threaded fasteners, as well as 1/8 thru 3/16" pop rivets.
But no matter how many we buy ahead of time, we never have enough of the right length for whatever it is we're building
Unread 16-12-2013, 19:41
mman1506's Avatar
no team (WARP7)
Any recommendations on what riveter to buy? Are the cheap ones OK?
Unread 16-12-2013, 19:44
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
http://m.harborfreight.com/3-16-inch...not%20provided
Art Dutra IV
世上无难事,只怕有心人.
Unread 16-12-2013, 20:52
DonRotolo's Avatar
Back to humble
FRC #0832
For bolts, we have standardized on 1/4-20, mostly socket head cap screws but also button head allens and hex heads. We also use #10-24 (same heads plus flat head allen) and very limited #4-40 (pan head philips only).
We get every size up to 1.25", then every 1/4" to 2", then every 1/2" to 3" (except the 4-40, we get 1" and 2" only). We stock between 100 and 500 of each size, larger amounts generally at smaller sizes.
Thousands of washers, lock washers, nuts, stop nuts. And several feet of all-thread, just in case.
For rivets, we buy the good ones from Bolt Depot in 1/4" and 1/8", some with steel mandrels, some with aluminum. We have a pneumatic rivet gun too. We have used the Harbor Freight ones in 1/8", they were fine, low-strength areas only though.
Unread 16-12-2013, 21:19
MrForbes's Avatar
AKA: Jim
We use a small cheap rivet gun at school. I do have a cheap large rivet gun too, which I've loaned the team for pulling the 1/4" rivets we used to assemble our chassis last year.
Don has good suggestions...I guess his team takes materials more seriously than we do! Ace Hardware is just down the street from the school, I stop by almost every day on my way to build
Unread 16-12-2013, 21:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Attention to detail with fasteners is a big deal for us. Every fastener we use is specific to the application. It would be grossly impractical for us to pre-order anything. We try to standardize on 10-32 thread size, button head for most things and countersunk flat head for bearing blocks, but there are plenty of areas where 10-32 thread is not a good choice. We spec our fasteners, and order from McMaster when needed, and they show up a day or two later.
We do keep a lot on-hand, but it's all remnants from the above, and used primarily for prototyping and maintenance purposes.
Unread 16-12-2013, 23:17
safiq10's Avatar
safiq10 safiq10 is offline
FRC #2950 (DEVASTATORS)
safiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond reputesafiq10 has a reputation beyond repute
Sorry rookie question what are fasteners and what do they do! ( I most likely know what they are but cant think of them right now)
Unread 16-12-2013, 23:28
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
I have what amounts to a small hardware store in our build room closet...
Our standard fastener size for mechanical elements is #10-24. I have every size in 0.25" increments from 1/2" to 2" and 0.5" increments to 3"
Electrical items tend to be #8-32. We have every size from 1/2" to 2" in 0.25" increments.
We have an assortment of 1/4-20, 5/16-18, 3/8-16, 1/2-13. of varying lengths from 3/4" to 6"
We have a few #6-32 and #10-32 screws that we purchased for COTS items that use them.
We have every size mentioned in regular and ny-lock nuts.
We also have #4-40 and #3-48 screws for a few tiny parts. (And most importantly, holding the cRIO breakout boards in...)
We will buy other hardware as needed by design during build season, but that's a small list of what we keep on hand so we don't have to worry about not having a fastener when needed.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 16-12-2013, 23:29
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
Hardware that holds stuff together, like screws, bolts and rivets
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 16-12-2013, 23:35
AdamHeard's Avatar
Lead Mentor
Disagree with that, we prestock a good selection of #10-32 and it saves us a bunch of time (and $$$ on shipping).
If we need something odd we didn't prestock, then we order. But you say stocking ANYTHING is grossly impractical is a huge hyperbole.
Unread 16-12-2013, 23:40
Pratik Kunapuli's Avatar
Pratik Kunapuli Pratik Kunapuli is offline
Probably browning-out on Astro-Turf
FRC #1648 (G3 Robotics)(EWCP)
Pratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to allPratik Kunapuli is a name known to all
In general, our team decides on what fasteners we are going to use for that year, and then orders a large amount of them form McMaster. We always have left overs at the end of our season which are sorted and kept in containers in the shop closet. When prototyping, we use the leftovers, but when assembling the robot we use the new bolts/screws/rivets. In general, we use socket head cap screws (SHCS), but also use button heads, low clearance, or even counter sunk bolts/screws when clearance is an issue. For rivets, we pretty much only use 1/8" blind aluminum rivets.
Last year specifically, we used a standard size of 10-32, of varying lengths. Occasionally we used #6 and rarely used #4 bolts. From what I've seen #10 and 1/4-20 are pretty standard in FIRST.
Official Driving Record: 101-59-0
2012-2015 Student 341 Miss Daisy
2015-Current Mentor 1648 G3 Robotics
Unread 17-12-2013, 01:29
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Fasteners are generic names for things that fasten two or more things together. Bolts and rivets are the most obvious examples, but they include (by some definitions) rivenuts, nuts, washers, snap rings, split washers, wood screws, etc.
Like Adam, we use mainly 3/16" rivets (ordered in massive quantities off McMaster) and 10-32 screws where rivets don't make sense. We have a small store of other sizes of fasteners (we used to standardize for 1/4"-20, so we have a fair bit of that), but generally have to order the weird stuff. We also keep 80-20 nuggets and other hardware around.
It's important to note that keeping screws and stuff organizes is just as important has having the right ones. If you can't find a fastener, the money you just spent on it isn't really doing much good.
-Plutarch
Unread 17-12-2013, 12:59
DonRotolo's Avatar
Back to humble
FRC #0832
We just hate to run out of stuff like nuts and bolts. The hardware store is just down the street, and we have several options for large amounts of hardware...all of which are probably closed 9:30 tuesday nights...
