Go to Post Sounds more like competition for Kentucky Fried Chicken - "I'll have the 3-piece dinner, a Winglet and two thighs..." - Dick Linn [more]
Unread 09-01-2002, 23:54
Ian Mackenzie Ian Mackenzie is offline
FRC #3683
Ian Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond reputeIan Mackenzie has a reputation beyond repute
Pressure angles for motor pinions
In all the data I've managed to find on the motors in the kit, the pressure angle of the gears often seems to be missing. I know that the Fisher-Price pinion and the smaller diameter part of the brass gear for the Chiaphua motor are both 32 diametral pitch, but what pressure angles are they (20 or 14 1/2 ?)
-Ian Mackenzie
Team 188
Unread 10-01-2002, 08:33
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
The Chiaphua gear is NOT 32 DP. It is a 36 DP gear. It is also not standard in that it uses a 25 degree pressure angle AND it is enlarged -- the gear data is on the print that I posted on this site and (less legibly) in Update #1 from FIRST.
The Fisher Price IS a 32 DP gear. It is a more or less garden variety 20 degree pressure angle, full depth gear (the profile is not quite the standard used for steel, but it is close enough for anything we at FIRST will ever care about).
Before you ask, the drill motor is a standard, 0.7 module, 20 degree pressure angle, full depth gear.
Joe J.
Unread 10-01-2002, 13:31
Larry Barello Larry Barello is offline
http://www.barello.net
#0492 (Titan Robotics Club)
Larry Barello has a spectacular aura aboutLarry Barello has a spectacular aura about
How do you suggest we connect to the Chiaphua gear cluster? Are 36pd 25deg spur gears available off the shelf?
Unread 10-01-2002, 13:43
Kit Gerhart's Avatar
Mentor, coach, whatever--
FRC #0233 ("The Pink Team")
Use the cluster in the kit, or make one
The 36 PD, 25 deg gear is very non-standard, so your main choices are probably to use the gear cluster that came in the kit, or make your own wire EDM gears.
The small gear on the cluster is standard 32 pitch. Only the one mating with the motor shaft is weird.
Team 1062, The Storm, 2003
Unread 10-01-2002, 13:48
Great: the driving gear is standard. That is what I needed to know. I can gut the Fischer Price gearbox for further reduction of the Chiaphua.
Unread 10-01-2002, 15:05
AKA: Dr. Joe
FRC #0088 (TJ2)
Having a 5:1 reduction from the Chiaphua be the INPUT to a gearbox designed for the Mabuchi motor as input is likely to produce a lot of small plastic shards (wear your goggles please).
Seriously. At 5:1 the Chiaphuas have as much torque as the window motors but have the speed of the drills in high gear. Believe me this is not likely to be a good thing.
Joe J.
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
Auto Air Pump Code zorro Programming 25 05-01-2003 16:50
pressure sensors archiver 2001 0 24-06-2002 02:15
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
Pneumatic pressure sensor Curtis Williams Pneumatics 3 04-02-2002 20:09
