Go to Post It's your duty in FRC to your teammates and alliance partners to put the most competitive robot possible on the field. - Chris is me [more]
Unread 17-12-2013, 13:23
DonRotolo's Avatar
Back to humble
FRC #0832
Re: 3.6GHz 802.11y for Competitions
Originally Posted by yash101 View Post
By the way, this is a tad off-topic, but why does 5GHz not penetrate walls so easily, where 2.4GHz will cover my entire (large) home?
More than a tad. Nonetheless: Different frequencies have different propagation characteristics. At 3.5 MHz you can communicate around the world with one watt of power, while at 400 MHz you can't go more than a hundred miles with 1500 watts*.
The higher in frequency you go, the more the radio waves behave like light. 2.4 GHz passes right through wood, plaster, etc with only a little attenuation. 5 GHz is affected much more. 10 GHz is even worse in that respect.
*There are some very specific exceptions, such as tropospheric ducting, but I'm discussing 'normal' propagation here.
Unread 17-12-2013, 19:37
seg9585's Avatar
seg9585 seg9585 is offline
AKA: Eric
FRC #4276 (Surf City Vikings)
seg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond reputeseg9585 has a reputation beyond repute
Like light? Radio waves are light.
Anyway, many of you are forgetting that FIRST is a worldwide activity, and just because the United States has permitted licensed usage of the 3.6Ghz band doesn't mean the rest of the world has. Would you really want our Brazilian, Israeli, Mexican, etc teams getting into trouble with their local regulators over FIRST hardware?
http://en.wikipedia.org/wiki/List_of_WLAN_channels
My FIRST legacy:
Team 204 Student 2001, 2002 (Voorhees, NJ)
Team 1493 College Mentor 2006 - 2008 (Troy, NY)
Team 2150 Intern/Professional Mentor 2007, 2009 (Palos Verdes)
Team 4123 Lead Engineering Mentor 2012 (Bellflower, CA)
Team 4276 Engineering Mentor 2012-2016 (Huntington Beach, CA)
