Re: Your Versachassis??
We like 3/16" aluminum pop rivets. Perfect size and not too small while not taking up too much room. I know the holes on the VersaTubing are 5/32, so we're just going to take a 3/16" drill bit and widen them up a bit. Wouldn't take more than a minute or so to do all of them.
Definitely.
Alright we have always used 1/4" bolts and never have used rivets on a drive train so you could say we are "nervous" aha.
#7
1/4 rivets are overkill so I wouldn't be worried. All of our frame was connected with 3/16" rivets last year(no welding, no bolts). Even 1/4-20 bolts are overkill. We switched to 10-32 for everything last year which can save you a bit of weight.
#10
I'm not sure when the manual will be released, but I'd argue it's coming up within the next week if not sooner. |
#11
Knowing the people who worked on this, I'd bet that almost all of those parts should be ready by (or before) kickoff, but they want to make extra- extra-sure that all their products are really high quality by the date they said they would ship them by. In any case, like Andrew said, the 15th is right around when most people will start to want those parts anyway. |
#12
I would recommend that in some applications to think twice about using rivets. We have all too often riveted pieces together only to be stuck having to drill them out when something needs to be changed or taken off the robot. Using nuts and bolts to assemble your robot then replace them with rivets is a great idea when you find yourself designing on the fly. Nuts and bolts are also great when making mechanisms modular or to swap replacement parts easily. We designed our shooter plate this year that with four bolts we could drop our shooter motors and wheels out of our robot for repair or replacement. Technically you can drill out a rivet faster than taking off a nut or bolt but dealing with metal shavings flying around your robot isn't always the best idea when electronics are involved. |
