Go to Post Woo for speculation! - Eugenia Gabrielov [more]
Unread 17-12-2013, 20:40
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Re: Your Versachassis??
Originally Posted by Andrew Lawrence View Post
The transmission is connected to the inside of the tubing. The holes next to the output shaft are connected to the outer half of the bearing block and this holds the transmission and the block together. Alongside that there are two slightly larger mounting holes on the side of the transmission about 6 inches apart (that number may be wrong, but I'm pretty sure that's it, doesn't matter though) that both hold the transmission together and hold it to the inside the frame.
I got ya, so im assuming you use pop rivets, what size? We used 1/4" aluminum rivets last year I believe.
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
