Go to Post Mentors can't get tired, it says so in the manual. SENIOR mentors, therefore, must have a different manual! - KathieK [more]
Unread 17-12-2013, 19:16
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
Your Versachassis??
Our team has talked about to new versachassis but have wondered with all the different parts what exactly which combination we should get. So we are asking you, if you were to go order everything for your versachassis, what would YOU get??
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
Unread 17-12-2013, 19:58
Andrew Lawrence
Posts: n/a
Re: Your Versachassis??
This would be my versachassis. We ran a similar setup we made ourselves in the offseason and loved it.
The list is:
- 27" long 2x1 VersaFrame tubing (x2)
- 25" long 2x1 VersaFrame tubing (x2)
- VersaFrame Gussets (x4) (specifically 4 90º angle gussets)
- VersaBlock (x5) (4 for the outside, the two sides of the fifth are used as the outer blocks of the center)
- 4x1.5" Colson Performa wheel (x6)
- WCP Colson Live Axle Hub (x6)
- 36" of 1/2" hex shaft (x1)
- 3 CIM WCP SS geared for 16 ft/s through the 40-34 gear kit at a 5.35 ratio (x2)
- Spiral Cam Tensioner (x4)
- 24 tooth 9mm HTD pulley (x8)
- 120 tooth 9mmx5mm HTD timing belt (x4)
- CIM motors (x4)
- Mini CIM motors (x2)
- 22x27" plywood base 6mm thick (x1) (Local hardware store)
This is literally everything in the picture except for the washers and bolts on the ends of the wheel shafts, and the rivets. Solidworks puts the weight at 34 lbs (I put all the correct weights and materials in for each object). Our driver loved the setup.
Unread 17-12-2013, 20:10
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
with the versa blocks, the 5th one is split, each half used on the middle outside. What is used on the inside and how did your transmission "connect"?
Unread 17-12-2013, 20:23
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Just kidding around but when I read this topic title I was like what about: http://us.versace.com/
Say versachassis and versace fast.
Unread 17-12-2013, 20:28
Andrew Lawrence
Posts: n/a
The transmission is connected to the inside of the tubing. The holes next to the output shaft are connected to the outer half of the bearing block and this holds the transmission and the block together. Alongside that there are two slightly larger mounting holes on the side of the transmission about 6 inches apart (that number may be wrong, but I'm pretty sure that's it, doesn't matter though) that both hold the transmission together and hold it to the inside the frame.
Unread 17-12-2013, 20:40
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
I got ya, so im assuming you use pop rivets, what size? We used 1/4" aluminum rivets last year I believe.
Unread 17-12-2013, 21:01
Andrew Lawrence
Posts: n/a
We like 3/16" aluminum pop rivets. Perfect size and not too small while not taking up too much room. I know the holes on the VersaTubing are 5/32, so we're just going to take a 3/16" drill bit and widen them up a bit. Wouldn't take more than a minute or so to do all of them.
Unread 17-12-2013, 21:04
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
We purchased the 1/4" rivet gun from harbor freight...think that has enough power to pull rivets for a chassis?
Unread 17-12-2013, 21:24
Andrew Lawrence
Posts: n/a
Definitely.
Unread 17-12-2013, 21:29
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Definitely.
Alright we have always used 1/4" bolts and never have used rivets on a drive train so you could say we are "nervous" aha.
Unread 17-12-2013, 21:37
Andrew Lawrence
Posts: n/a
We just used rivets for the first time on our offseason bot and absolutely loved them. They're essentially weightless, extremely strong given a tight and concentric hole, and simple to use. 10/10 would rivet again.
Unread 17-12-2013, 21:56
RonnieS's Avatar
AKA: Ronnie Sherrer
FRC #0314
Do you happen to know when the VersaChassis user Manuel will be released? and we are realy questioning using the Versa stuff because of the shipping date not being till the 15th on a lot of the things we would need. Have you looked into that?
Unread 17-12-2013, 21:59
FRC #1836 (MilkenKnights)
1/4 rivets are overkill so I wouldn't be worried. All of our frame was connected with 3/16" rivets last year(no welding, no bolts). Even 1/4-20 bolts are overkill. We switched to 10-32 for everything last year which can save you a bit of weight.
Unread 17-12-2013, 22:10
Andrew Lawrence
Posts: n/a
Do you happen to know when the VersaChassis user Manuel will be released? and we are really questioning using the Versa stuff because of the shipping date not being till the 15th on a lot of the things we would need. Have you looked into that?
I honestly don't have a problem with the parts not shipping until the 15th. It gives me time to design my robot in CAD for the game, and since all of the parts for the VersaChassis are available for CAD on the WCP/VEXpro websites I can easily design my drivetrain in an hour at most, and move on knowing I can change my drive at any time because the VersaChassis product line is so interchangeable. So if kickoff is January 4th, that gives me a week and a half to design most of my robot in CAD, I order my parts when I know what I want, then they ship on the 15th, which is a Wednesday, so that I know when they arrive at or before Saturday I have a simple and functional drivetrain model to work off of, and in a matter of hours I'll have a functional drivetrain we can use at the end of week 2.
I'm not sure when the manual will be released, but I'd argue it's coming up within the next week if not sooner.
Unread 17-12-2013, 22:36
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Rivets are good. We've used 1/4 rivets which integrate nicely when we use the kitbot chassis. They are overkill for most applications but on the kitbot they are great. 3/16 is perfect for pretty much all FRC applications.
I would recommend that in some applications to think twice about using rivets. We have all too often riveted pieces together only to be stuck having to drill them out when something needs to be changed or taken off the robot. Using nuts and bolts to assemble your robot then replace them with rivets is a great idea when you find yourself designing on the fly. Nuts and bolts are also great when making mechanisms modular or to swap replacement parts easily. We designed our shooter plate this year that with four bolts we could drop our shooter motors and wheels out of our robot for repair or replacement.
Technically you can drill out a rivet faster than taking off a nut or bolt but dealing with metal shavings flying around your robot isn't always the best idea when electronics are involved.
1058 PVC Pirates 2016 - xxxx
