Go to Post Lucky breaks and trying to minimize failures or moments of retardedness are what these games are all about, like any sport. - Bill Gold [more]
Unread 16-12-2013, 16:58
John16 John16 is offline
AKA: The JP, or John Pyeatt
FRC #1828 (BoxerBots)
John16 is an unknown quantity at this point
Prefabbed Drive Train
We recently purchased an AndyMark nano-tube drive chassis. We've hooked up 4 CIMs to it, two to drive the rear four wheels, and two for the front two wheels. When reversing directions quickly, we seem to be able to drop the voltage low enough to reset the router, but only with either of the two front motors connected. Disconnecting the two from, we can run all day without the issue. Any ideas why this is happening, and how to overcome it?
We've previously used four CIMs in our drive train before, but with chains. We weren't sure if the previously not experienced sudden current draw was coming from the almost zero lag of the gear system.
We greatly appreciate any and all assistance in understanding this. Thank you.
Unread 16-12-2013, 17:05
DarrinMunter's Avatar
DarrinMunter DarrinMunter is offline
Fixes parts that leak smoke
AKA: Darrin Munter
DarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to beholdDarrinMunter is a splendid one to behold
Re: Prefabbed Drive Train
Are you using the 12 to 5 volt DC to DC converter?
This converter gets plug in to the PD at the regulated 12V output.
2014 Wisconsin Engineering Inspiration Award, CIR Engineering Excellence Award
2013 Croosroads Engineering Inspiration Award
2012 BMR Judge's Award, 2011 BMR Regional Champions, BMR Motorola Quality Award, BMR Autodesk Excellence in Design Award, 2010 BMR Regional finalists; 2009 BMR General Motors Industrial Design Award; 2008 BMR Engineering Inspiration Award; 2007 BMR Rookie All-Star Award
Darrin Munter - N9SDD
Advanced Technology Services
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
Do you have the router plugged into the 5v port of the PD board, or are you using the dedicated 12v port of the PD board (not the normal 12v ports on the side), with a 12v-5v dc-dc convertor to step down to 5v?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 16-12-2013, 17:06
Is your radio power wired to the special 12v protected power supply?
Voltage dips are more likely to affect the radio when it's wired to a regular WAGO connection (incorrect).
Take a look at your Driver Station log to see the voltage graph. How low is it going?
Certainly, stalling 4 CIMs by a quick reversal can draw the voltage quite low, but the radio is unlikely to brown out from it.
Last edited by Mark McLeod : 16-12-2013 at 17:07. Reason: Everybody has the same reaction :-)
Unread 16-12-2013, 17:17
magnets's Avatar
magnets magnets is offline
There's a million things that could cause this.
Here's a list of the most probable
Is you battery charged?
Have you tried a different battery?
Do you have the radio wired correctly?
Is there too much resistance in the drive train?
Did you lubricate your gears?
Do you have an electrical problem?
Is there a loose connection?
Do you have a weird frame short issue or grounding issue?
Have you measured resistance from ground to your frame, and was it anything other than infinity/no connection?
Unread 16-12-2013, 18:23
  • We are using the dedicated 12V port on the PDB, along with the 12v-5v dc-dc converter.
  • There are no shorts to the frame.
  • Our lowest reading with a DMM directly from the Talons power side (not motor side) was 8.7V. A very noticeable dip which would give serious indication we are experiencing a huge current draw, which is why I'm here.
  • Gears are lubed
  • Yes, battery was fresh, each time.
Unread 16-12-2013, 18:26
MichaelBick MichaelBick is online now
FRC #1836 (MilkenKnights)
How old are your batteries?
Unread 16-12-2013, 19:14
AKA: Darrin Munter
Recheck the tightness of all the bolts, screws and nuts from the battery to the circuit breaker to the PD. Loose connections will cause a drop in voltage under heavy loads, and show full voltage when your robot is at a stand still.
Unread 16-12-2013, 19:45
Originally Posted by John16 View Post
We recently purchased an AndyMark nano-tube drive chassis. We've hooked up 4 CIMs to it, two to drive the rear four wheels, and two for the front two wheels. When reversing directions quickly, we seem to be able to drop the voltage low enough to reset the router, but only with either of the two front motors connected....
Are you sure the router is resetting? Can you describe the exact symptoms?
What motor controllers did you use in the previous drivetrain and the present one?
Unread 16-12-2013, 19:49
ErvinI ErvinI is offline
AKA: Ervin Ibadula
FRC #0865 (Warp7)
ErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really niceErvinI is just really nice
This sounds very similar: http://www.chiefdelphi.com/forums/sh...ad.php?t=98128
There were multiple issues found that could have led to brownouts on that robot. However, the main one on that robot seems to be a non-issue on yours.
From that thread:
Originally Posted by Phalanx
I was working with / trying to help these guys yesterday at Brunswick Eruption. There were numerous problems being identified and we were trouble shooting them one at a time. This is as far as were able to get.
1) The ground wasn't firmly attached to the stud on the PD. Fixed
2) One Gear Box was loose and wobbling. Fixed
3) We measured the power drop between the studs on the PD with a multi-meter when they changed directions it went from 12volts to 8volts and lower.
We recommended fully charged batteries.
4) I didn't check if the CRIO rebooted, but the DLINK rebooted every time.
5) They also have the D-Link powered by a 20AMP circuit like James posted previously.
6) Lastly, I'm wondering if direct driving Mechanum Wheels using 4 - CIMPLE Boxes wasn't enough of a mechanical reduction and hence cause too much draw.
On another note, do radio brownouts actually occur at 8.7 V? I thought it was 6V or lower; I remember our motors getting dangerously close to 6 V last year with no brownouts, but it's been sometime.
Currently a student at the University of Toronto - Mechanical Engineering
FRC 781 alumni
Unread 16-12-2013, 20:58
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
The radio should not be browning out at ~8 volts, the 12 volt regulated output on the PDB is rated for a minimum input of 4.5 volts.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 18-12-2013, 08:15
I thank you all for your replies. There are no loose nuts (besides me).
We are using talons.
We know it "shouldn't" be browning out the radio, but it is.
I just received some information from a teammate I need to process. It may shed more light on this.
Unread 18-12-2013, 08:26
Well, seems that one of our members is positive our digital sidecar is plugged into the dedicated port instead of the 12v-5v converter.
We will try swapping those this saturday and see if that fixes our issue.
Unread 18-12-2013, 09:01
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
Did you try running only with the front wheels connected to see if there is a 4 CIM issue or if there is an electrical problem with the front wheels? Is the router mounted near a front CIM or its wires (I like to twist the CIM wires to reduce radio interference).
Unread 18-12-2013, 10:30
I saw more than one robot miswired that way last year. One of them was at the Championship, having passed inspection at two previous competitions. I don't know what could be improved in the documentation to make it more clear where everything should get its power.
