Go to Post Anyway, it's a global program and a global world. - Christopher149 [more]
Unread 18-12-2013, 11:44
pyroslev's Avatar
pyroslev pyroslev is offline
VirginiaFIRST FTA
AKA: Jack of all trades, Master of few
no team (Forget not 616)
pyroslev is on a distinguished road
Re: [FTC]: HiTechnic Motor Controllers - Motor and Power wires fall out???
Doing that will help you out as much as anything. Just remember to peek in the box to check you're wiring.
This will also help reduce your risk of static electricity, provided the box is entirely enclosed and isolated from the frame.
"Complications arose, ensued...were overcome." "I'd trade 500 CNC machines for one good hearted student."
From December to April, since 2002, I forfeit my mental sanity for perfect insanity.
Unread 18-12-2013, 15:59
aklego aklego is offline
FTC #3595 (Schrödinger's Hat)
aklego is just really niceaklego is just really niceaklego is just really niceaklego is just really nice
Tetrix wires come with tinned ends which is a huge no-no when using screw terminals. After tightening the solder will creep and a few days later the wire will be loose. Bare wire is considerably better but better still are ferrules. Since we started using them the only loose wire we've had has been self-inflicted.
This is the ferrule set we bought: http://www.automationdirect.com/adc/...Tools/BM-80418
The crimping tool is of medium quality--perfectly adequate for what we do but there are much nicer ones.
On the same topic, the Tetrix power switches come with connectors crimped onto tinned wires--this is absolutely the wrong way to get a reliable connection. Crimp on connectors should only be used on bare wire.
let tau = 2pi
