Go to Post Do you know how, say, Native American cultures were kept? They had storytellers, sages, and the like. They passed on their legends and culture to the next generation. So will we. - EricH [more]
Unread 10-02-2003, 01:38
Don Reid Don Reid is offline
Don Reid will become famous soon enough
No, it is scaled to sensor_counts / degree. Sensor_counts are the values from the analog input. These (and loops) are dimensionless.
If the machine is turning at one degree per sample time, then the analog input will read 127+53 each time it is sampled.
If it is moving slower (I hope it is, that's FAST!), then the number will be smaller. This means that each time thru the loop, the new motion will be less than 1 degree, so you have to accumulate in smaller units. You can accumulate these "sensor_counts" until there is enough to total at least one degree. Then you increment the degree counter, and subtract 53 from the sensor_counts accumulator.
The logic for values less than 127 (turning the other way), is left as an exercise for the reader(s).
Don Reid
Anyone know where to buy a spare yaw rate sensor? Jim Meyer Technical Discussion 11 30-03-2003 21:18
Aux Fuse 3 (Yaw Rate) Josh Hambright Electrical 0 18-02-2003 08:22
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
Yaw Rate Sensors dense Technical Discussion 4 10-01-2002 08:28
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
