Go to Post Of course even though its less than a week until kickoff, dave can still change the rules to make bearhugging me in automode a bonus - Mike Schroeder [more]
Unread 18-12-2013, 23:41
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: [FTC]: Split Clamp vs Axle Hub
Mount gears or sprockets with non-split hubs directly onto wheels.
Keep gear/sprocket as close to wheel as possible.
Run four long screws all the way through the entire stack - wheel, hub, and gear/sprocket.
Use flat or button head 6-32 screws where close spacing is needed , and countersink for heads as needed
Then drive wheels directly, with axles merely free spinning in the sleeve bearings. No torque applied to axles.
Tetrix axles bend easily and driving wheels via torque applied to Tetrix axles is a very unreliable concept.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
