Go to Post 100% of the robots on Einstein in 2009 had hard plastic wheels for their drive train. - efoote868 [more]
Unread 18-12-2013, 21:45
ksafin's Avatar
ksafin ksafin is offline
AKA: Kirill Safin
FRC #3992 (Eagles Robotics Xperience)
ksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant futureksafin has a brilliant future
The age old question - bumper mounting
Hey all.
We've suffered from difficult-to-mount bumpers for the past two years and wanted some input.
How does your team do it? Are there great ways to do it?
ALSO, what's the best way of making bumpers - IE, make each side a separate piece? Make the whole thing somehow 1 unit? Make a U-shape that's 3 sides to slide on, and then finish off by mounting the last side? What has the best balance of aesthetic appeal and ease-of-mounting?
As for mounting, I keep seeing something like a shallow aluminum c shape onto which bumpers slide onto, which I can't for the life of me understand!
Thanks.
FTC Teams 5257, 6568 & FRC Team 3992
2014 FTC WORLD CHAMPIONS
14 Trophies in 3 Years
Unread 18-12-2013, 21:53
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is offline
Division by Pirates
FRC #0229 (Division by Zero)
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
Re: The age old question - bumper mounting
What we've done the past few years is bolted some small pieces of c-channel with a hole onto the back of our bumpers, and then put the small pieces of c-channel on top of our frame, line up the c-channel holes with holes on our frame, and put a pin through them. As for amount of sides with separate bumpers, two years ago we used one for each for each side, and this year we made one set to fit on all sides. There really wasn't too much of a noticeable difference between the two, other than it took more time to make the singular bumper than the separate ones.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
Unread 18-12-2013, 22:08
yash101 yash101 is offline
AKA: null
Though I haven't seen how one works, bumpers with a quick release seem quite nice because changing bumpers can be done with no or less tools!
MAKE SURE THE BUMPERS DONT FALL OFF IN THE MIDDLE OF A MATCH!!!
Unread 18-12-2013, 22:11
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
We take our bumpers off and bolt them on once per competition for inspection. After that we use reverseable bumpers that many do with Velcro, but this year we sewed in a bungee cord to allow us to flip quickly without having to secure anything.
Our mounting is simply a piece of 20ga aluminum sheet that is bent at 90 degrees and screwed to the bumper with 1/2" wood screws. We then drill holes in the aluminum and run bolts through every 8" or as rules require to attach to our frame. Bolts may not be quick, but we've never had loose bumpers and since we rarely remove them we could care less about speed.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 18-12-2013, 22:17
Abhishek R Abhishek R is offline
FRC #0624
Abhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond reputeAbhishek R has a reputation beyond repute
We usually have bolts sticking up from the frame of the robot and then holes in the bumper mounts so we basically just drop the bumpers down over the robot and secure it with wingnuts. Combined with the reversible fabric colors, it takes about 30 seconds to switch/take-off the bumpers.
It also takes no tools at all to remove or put on.
2012 - 2015 : 624 CRyptonite
Team Website
Unread 18-12-2013, 22:22
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
We always mount our bumpers on 90º angle brackets directly to the top of the c-channel using quick release pins. When we use this system, we can change bumpers in around thirty seconds by simply pulling the pins out, kicking the robot to make the bumpers fall off, line up the other set, and slide the pins back in. The pins are strong enough to keep the bumpers on the robot even when it's upside down (we use the variety with a ball bearing at the bottom of the pin), but easy enough to remove that they're not too much of a hassle for us to hate changing them.
EDIT: These are the pins we use.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 18-12-2013, 22:23
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
For this year's game, our original plan was to have 1 wrap-around bumper fall into place and snap on, making a secure fit. However, the quick release system didn't end up working as the pins we ordered at the time were too short.
For simplicity's sake, we decided to use just add two pieces of L-angle aluminum to the back of the bumper, mounted such that when the bumper came down on the robot, the bumper would be resting on top of the drivetrain rails. We then used wing screws and some 8020 drop-in nuts to secure the bumper in place.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 18-12-2013, 22:27
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
We've used a 2-pin quick release system for the last 2 years as per the pictures in this post:
http://www.chiefdelphi.com/forums/sh...4&postcount=87
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 18-12-2013, 23:22
Dave McLaughlin's Avatar
Dave McLaughlin Dave McLaughlin is offline
Dave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond reputeDave McLaughlin has a reputation beyond repute
For the last few seasons 1983 has recessed our bumper backing into the frame and then pop riveted through the top and bottom to secure it. We think that the end result is not only aesthetically clean, but it adds to the structure of the frame. The recess is created by extending the upper and lower sheer panels past the vertical walls of the frame. If you look closely you can see the thru holes for the rivets in the attached picture.
http://team1983.files.wordpress.com/.../wp_001144.jpg
Unread 19-12-2013, 00:27
Oblarg Oblarg is offline
AKA: Eli Barnett
80/20 angle brackets (the small type) attached directly to the frame have always been the standard method on 449, with the bumpers mounting directly through them via. wing nuts. Easy to set up, and it works well.
Last year, 4464 mounted our bumpers through holes in the c-base using washers and wing nuts, but this was a pain and I hope we don't do it again.
Both teams used separate bumpers for each straight run on the frame perimeter, and that's worked well enough that I don't see any reason why we'd change it. Corner bumpers just seem harder to make.
I am proud to report that I have never, ever seen a bumper on one of our robots fall off during a match.
"The breakfast of champions!"
Unread 19-12-2013, 10:05
I still like the added structure of having a solid full wrap bumper with no gaps. Here is our take on the quick change color set up. Just sew a loop in and fish 8 feet of elastic through, a few hog rings later and never look back.
Andrew Basse
Unread 19-12-2013, 10:25
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
We usually have had a C-Channel chassis so we mount vertical 80/20 channel pieces periodically around the perimeter. These pieces are only several inches high and have a thumb screw with the part you would grasp facing the inside of the robot. The bumpers have 14-20 buttonhead bolts screwed into them that stick out just enough to drop them into the 80/20 sections. Usually works pretty well, sometimes we have to use a hammer to give the bumper a little motivation.
As for our actual bumpers, we usually make 2 sets of 2 bumpers. Usually right/left or front/back depending on our robot dimensions or if we have to have a gap in our bumpers that year.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 19-12-2013, 11:03
mmcewen's Avatar
mmcewen mmcewen is offline
AKA: Keeper of the Fish
FRC #4595 (Infinity Robotics)
mmcewen is an unknown quantity at this point
We drilled holes through the backing plywood and glued pins in to it. The pins line up with holes in the robot chassis and are fastened with small wire pins.
Our only problem was reaching the pins in the middle on our shooter side. It's super quick but only if you can reach your hand in the right spaces.
Unread 19-12-2013, 11:33
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
This was an awesome way to mount our four corner bumpers to the c-frame base. We were able to change bumpers in about 45 seconds.
Mount pieces of oversize c-channel to the back of the bumper, lined up with the holes on the robot chassis
http://www.chiefdelphi.com/media/photos/39229?
Use long bolts with spacers (made from air hose) as mounting pins. You can use wing nuts to secure them, but we had no problems just inserting the pins.
http://www.chiefdelphi.com/media/photos/39230?
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
Unread 19-12-2013, 13:08
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
We generally use a 1x1 square tube (with radiused edges) to rim the chassis and provide bumper support. The kit channel nests very nicely over the square tube. We fab/weld support clips from 2 short pieces of the kit channel and use a quick release pin at each mounting point. Making the bumpers in L-shaped sections will make them even more secure when mounted. See a model in this thread:
http://www.chiefdelphi.com/forums/sh...d.php?t=111344
Having said all this, post #11 clearly takes the cake, and we'll definitely look into this approach this coming year.
FRC Team 3489 "Category 5"
