Go to Post This is a risk. Life is full of risks. FIRST is life... therefore, FIRST is full of risks. - Andy Baker [more]
Unread 19-12-2013, 12:57
techhelpbb's Avatar
FRC #0011 (MORT - Team 11)
Re: MIG welding and advice
Originally Posted by JamesCH95 View Post
100% Ar is suggested by many, but is not always the best shielding gas. A helium/argon mix is best for welding aluminum (TIG or MIG imo) because helium has much better heat transfer properties. This lets gas-cooled torches run cooler, and transfers more heat to the work. Both of these increase the capabilities of the welder. I like 50/50 mixtures, but even 25% helium makes a big difference. Helium also helps create a more stable MIG arc.
Absolutely correct.
However I rarely do that because I have a handy propane torch to preheat if need be and my welder is getting up there in power capability.
So I was curious (it's been a while) I called AWISCO where I buy my gas and they are getting back to me about the cost difference between the custom mix of 25% Helium / 75% Argon (I bought my previous tank elsewhere and apparently this was something unusual for them) and 100% Argon.
Last I looked the cost of the mixed gasses can reach a point where the cost of savings of the machine (though a donate machine can skew this) can make more sense to buy a more powerful welder (because it's cheaper over usage). Course if your usage is really low maybe it doesn't matter.
You can get a welding gas mixer but they are not typically cheap.
