Go to Post We were all rookies once. Some of us still are... - Wayne C. [more]
Unread 08-02-2003, 01:36
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
Image Discuss: 1083 Robot Frame
Unread 08-02-2003, 01:37
REVving up for a new season
FRC #2848 (All-sparks)
just curious how much does your robot weigh cause that frame is massive
Unread 08-02-2003, 12:25
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
... Are you planning on just having a frame??
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 08-02-2003, 13:26
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
Looks like the bot will just be a raming battle bot typle thing to knock down stacks? Or else... lots of drilling will need to be done.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 08-02-2003, 23:44
mistresshawk's Avatar
mistresshawk mistresshawk is offline
#1083 (The CREW)
mistresshawk is an unknown quantity at this point
Smile
I believe the weight was about 42 lbs when we weighed just the frame. I don't doubt it'll turn into swiss cheese once we've bolted everything down.
Hawke
' There are very few problems that can not be solved with orders ending with "or die."'
Unread 10-02-2003, 08:44
Nathan Pell's Avatar
Nathan Pell Nathan Pell is offline
FRC #0233 (The Pink Alliance)
Nathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to beholdNathan Pell is a splendid one to behold
Weight
We are at 120 lbs with the six wheels, electronics and gear boxes attached. We are about 20 over when we add the "extra" stuff.
Unread 10-02-2003, 10:56
LittleJohn LittleJohn is offline
LittleJohn is an unknown quantity at this point
Post
To directly answer your question - The frame itself is 42-45 lbs (depending on how you read the scale) - the six wheels (with hubs, rims, etc), are the same weight. The frame is 1/4" channel with 1/8" plate on the bottom - it's not as bad as it looks - the wheels however are Monster Truck level - so make a guess where the weight is going to come off.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Robot Mechanisms Image Database archiver 2001 0 23-06-2002 22:14
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
