Re: 3D Printing A Wheel
Yes, it's a test. We think it's quite possible (based off the advice of one of our mentors, who has built many 3D printers) that an extruded PLA wheel will be strong enough to endure the rigors of FRC. Our hope is to be able to cut down on manpower and machining time. We use 2-inch wide wheels with 971's tread attachment style, which take our sponsors several weeks to machine out of aluminum. In the build season, this is unacceptable, so we're trying to print them instead (using a modified design, obviously). A 1/4 scale model held my weight without cracking. If you want, I can post renders of both designs.
are you printing the wheel solid ?
Yes. |
o.o why not polyurethane casting and using hollowed version out of wheel to use as a negative because printing four or six of those wheels (at least) is going to be expensive
my math has it at 5 cents per gram if your using makerbot pla and 1.5 cents using an amazon competitor |
Interesting. I am curious to know how long it takes to print this wheel. Did you use one of the OpenSCAD parametric wheel programs available or is this your design? Any chance of sharing the STL?
#8
Here are some renders.
#9
Very good job with those ribs! Looks like a very efficient and strong use of material.
#10
I know what I'm doing all night.
#12
There was a team at North Star last year that used 3D printed wheels... I think it was 2175. They had a sponsor print them with material stronger than what you typically get for home printers, if I remember right. You should get in touch with them and see how their experience went over the season!
#13
